quick rack e36 or not
dips346
London Meets Main Man
Thu Oct 26, 2006 12:06 pm
need to know what is the best way to get a quick rack in a e30 and what would the turning lock be need to keep it power steering please
e21Jason
Thu Oct 26, 2006 12:16 pm
Hi Dips
The z3 1.8 rack
Jason
(ps the it's the mm travel per turn you need not lock to lock)
dips346
Thu Oct 26, 2006 12:18 pm
do know what the turn is
e21Jason
Thu Oct 26, 2006 12:36 pm
Quote from s14.net & possibly he
Jason
There has been some mis-information for a while about the E36 rack ratios plus I remember someone on here running an E36 3.0 M3 rack in their E30. I have spent some time doing some measurements plus confirmed this data direct with ZF (I know someone who works there who can access drawings on their system).
The standard way ZF quote on-centre (straight ahead) ratio is in mm/rev, which is the travel in mm of the rack bar per revolution of the hand wheel. The higher the mm/rev the faster the rack.
M3 3.0 - 39 mm/rev - the slowest available rack. This is a variable ratio but it is slower than standard until 200 deg hand wheel angle
M3 3.2 and standard E36 - 45.5 mm/rev - the M3 3.2 rack has restricted lock.
Z3 rack - 53.5 mm/rev - by far the quickest rack you can fit.
E46 compact rack - 50 mm/rev - apparently this also fits the E36
Because the M3 3.0 has a variable rack it has the smallest lock to lock at 3.0 turns but don?t be fooled it is the slowest by a country mile. A worthwhile upgrade for any 3.0 M3 (or a track based E30 with one of these fitted) would be to fit a standard E36 rack (or even a Z3 rack) which is what I did a year ago with a noticeable improvement.
Quote end
schuey
Thu Oct 26, 2006 12:53 pm
318 IS. Sold.
dips346
Thu Oct 26, 2006 12:56 pm
i tryed looking but the search engine is shit thanks mate :cool:
kevo
Thu Oct 26, 2006 1:13 pm
i put a standard e36 rack on mine (cost Ԛ£36 delivered and was easier to find), and i found a dramatic difference and i'm very pleased with it if yoyu want to know anything about how i did it give me a bell if you like .
kevo
07988618734
oze30
Thu Oct 26, 2006 3:46 pm
will it fit with a magnex 6 branch?
LKTe30
Thu Oct 26, 2006 5:04 pm
Is that all racks from any z3 or is there a difference in the years or what engine it has.
thanks
schuey
Thu Oct 26, 2006 6:36 pm
The 1.9 and 2.8 Z3 racks are the same,but the m-coupe are different. :cool:
318 IS. Sold.
