That doesn't sound good... (M20 problem)
NoSkill
A couple of weeks ago I got a 1985 323i, I noticed quite quickly that there was a 'ticking' noise, and reading here it seemed like an oil change was the first thing to try...
Unfortunately I don't have any money until later in the week when I get paid (was/am intending to do it over the weekend)
But I just got back to work and it's not sounding very good as well, at idle in neutral it's making a very wierd noise, almost like a machine gun, and there is a fair bit of vibration as well, seems to go mostly when running along at low revs in gear, but if I put a fair bit of throttle on it starts up again except louder...
I don't know that much about engines but only thing I can think of is that it's not firing on all cylinders, and the power does seem to be less than before so this could be correct i guess...
Coolant temperature was fine all the time, I've recently checked the oil and coolant levels, coolant needed topping up but not by much
Anybody got any idea's, I drive about 60-65 miles to work and back every day, and i've got no other transport so I really need to 'fix' it tomorrow morning :s
One thing I was tempted to try is what my mate did to his car when it was running roughly, which was whilst running take off the lead from each spark plug in turn, and the one that doesn't change the sound of the engine is the one that is causing the problem, is this worth doing?
Chris
Be carefull if you start grabbing HT leads, make sure your not actually touching any good earth on the car atleast.
ed325i
Could be a number of things it hard to say without hearing it. Could be a bearing gone, tappet come lose ....
Where does it sound like its coming from top/ bottom of engine ?
NoSkill
When I had a quick look after pulling up it didn't seem to be coming from any particular place, just generally from the engine, but i'll go have another look now...
NoSkill
Just been out to have a look, if anything it seems the sound is coming from the top of the engine, there was also a few 'click' noises, seemingly at random but loud enough to hear over the engine and I couldn't see anything that could be causing it...
Also, I did get a video from my phone but it's really bad quality so doesn't really capture the sound very well, but here it is anyway:
http://www.youtube.com/watch?v=lmN9c3oGdZ8
ed325i
I would take the rocker cover off and check the rockers.
NoSkill
I've got the haynes manual so I'll look through that now, is that something that will be fairly easy to do in an hour or two before work tomorrow morning?
Turbo-Brown
- Boost Junkie
Holy shit that sounds awful!
Definately check the rockers aren't miles out of adjustment and if they're not then start saving for a new bottom end
As a wild stab in the dark, you don't happen to live near a fishing shop do you? Only a white '85 323i appeared on my route to work a couple of weeks ago....wouldn't that make it a small world!
Is it possible the cambelt may have jumped a tooth?
NoSkill
I'll check the rockers tomorrow if I can, looking at the haynes it seems other than getting a new gasket it should be fairly straightforward,
It's a very dark grey 323i, and my daily route is bristol - trowbridge :p
Not sure on the cambelt, guess it's possible...
Guess taking it to work tomorrow is a no-go then? :s
Before something catches up and punches a hole in the head!ed325i wrote:I would take the rocker cover off and check the rockers.
Templ8e30
I heard a similar noise on a mates 320i, turned out to be serously worn big ends caused by running with low oil.
Once the engine was stripped you could see where the pistons had been kissing the head and had knocked all the carbon off the pistons and combustion chambers
Could also be rockers as already suggested.
Hope it's a quick fix
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
NoSkill
Pretty much given up the idea of it being a quick fix tbh, didn't bother looking at it today instead asked a colleague very nicely for a lift for the rest of the week :p
Plan is on saturday (after payday i think) head to a motor factors and buy oil, sump gasket and rocker cover gasket, then try to find out what exactly the problem is and fix it
Or the other option is, as a short term fix, buy handbrake cables for my mk1 mr2 and get that through it's mot and use that until i can fix the 323i :p
jonbuoy
If you are mechanically minded then this may be a quick fix but i can't see it being that quick tbh
By the sound of that, you may need to replace the cam but get some pic's up on this thread (Edit the heading to, "Pic's added") so the rest of us can have a good look
Good luck, and if your not sure what's going on, get someone to have a look dude
NoSkill
Well, I managed to take the rocker cover off this morning before work, but only just so not got any pics yet, but there were bits of *something* in there...
On a very quick inspection I could see 3-4 little pieces, about 3-4mm long and 1-2mm wide, seemed to make up around half off a washer-ish circle/ring type thing...
Don't know that much about engines but at a guess could it be a shim or something like that?
Whatever it is/was it seems quite bad, I'll have a better look tomorrow, take some pics and see if I can find all of the pieces and work out what broke to cause it to break this thing...
On another note the area under the rocker cover didn't look very well oiled, is this normal (guessing not)?
mikey-t
ouch! could it be a collet or valve stem seal?
NoSkill
Not really sure what either of them look like tbh, only thing I know other than a rough idea of the shape is that it was a shiny silver rather than the oily colour of everything else...
jonbuoy
Should'nt be a collet as they're smaller than that.mikey-t wrote:ouch! could it be a collet or valve stem seal?
If it was a collet, the valve would have fell through to the cylinder and bye bye piston and it won't be a seal as they are rubber
I had a feeling you was gonna say thisNoSkill wrote:On a very quick inspection I could see 3-4 little pieces, about 3-4mm long and 1-2mm wide, seemed to make up around half off a washer-ish circle/ring type thing...
I'm hoping this is not a bit of one of the valve spring's
You wanna make sure this has'nt been done on purpose!
NoSkill
jonbuoy wrote: I had a feeling you was gonna say this![]()
I'm hoping this is not a bit of one of the valve spring's![]()
How bad is it if it's a valve spring, from my limited knowledge I seem to be thinking that the valve spring is what closes the valve after the cam/rocker has pushed it down for the intake/exhaust cycle, so if it was broken i'd guess it the valve wouldn't fully close or something?
Also the last line, how would this have been done on purpose?
SGP
Sounds very like a smashed eccentric to me.one of the is probably missing from the end of one of your rocker arms.Easily replaced though.
If it ain't broke..
Fix it till it is
Fix it till it is
SGP
No.9 on the diagram.
If it ain't broke..
Fix it till it is
Fix it till it is
jonbuoy
SGP
The valve clearances are supposed to be checked and adjusted every 12000 miles.if they get too far out things start to break ie rocker arms etc.Hace a close look at the ends of the rockers and make sure all 12 are identical.
If it ain't broke..
Fix it till it is
Fix it till it is
NoSkill
ed325i, cheers for the diagram, I intend to spend around an hour or so (less if it takes less time) to look around, take pictures and recover as much as I can find of the pieces, hopefully the diagram will help me isolate what it once was :p
SGP, thanks for the suggestion, sounds possible, only had the car a couple of weeks and it's history is a complete unknown, and I'm guessing the 'ticking' noise would be explained nicely by wrong valve clearances?
jonbouy, ok, forgotten already :p on a more serious note I can't see how it would get in there unless it was there before I bought it, and don't think my dad would do that, although I do spend a lot of his money
NoSkill
Right, some progress
Just had a better look in the light, along with taking a few pics
Seems that on the diagram it's part 7 I think, the 'Rocker' itself I think, The bit that runs close to the cam is the bit thats broken, so that rocker rocks more than most :p
The rest of them are ok, and I think i've got all the bits now, it seemed to come off then break in half so not many bits to find I hope...
Anyway, here's some pics before some questions
And finally, the money shot:
And now for the questions:
Now I know what's wrong is it simply a case of buying another rocker and replacing it, or do they only come in sets of 12. Also how much am I looking at for a new rocker/set of rockers?
Is this likely to have damaged anything else, guessing it could have scratched the surface of the cam lobe?
Also I'm guessing this would would cause the valve not to open, hence the cylinder not firing and hence the noise/vibration? Basically is this the cause and the sole cause of my problems?
Fushion_Julz
The camshaft is pretty hard....this is unlikely to have caused damage the cam itself...
If it were my engine:
I would be a) making 100% sure I got ALL the bits of the broken rocker out of the engine even if that meant removing the head and/or sump....Bits of metal of that sort os size can cause quite a bit of damage if left to score bearings or block oilways!
b) asking why it broke in the first place....It appears to have stress cracked around the adjustment nut thread...Perhaps it was overtightened, but perhaps something happened that caused the valve stem to hit the rocker...That could be either a damaged/worn rocker shaft (and since you have to take that out to replace the rocker, it is easy to check) or it could be a piston to valve contact that occurred..That could be the result of cam timing (belt ,, pulley or adjuster problems) or it could simply be poor clearance of the rocker/valve gap...
I'm fairly certain it is not possible to remove the rocker shafts with the engine in the normal position...You either have to remove the head, or undo all the mountings to allow enough upward adjustment/tilt of the engine to be able to extract the shafts...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
NoSkill
Cheers for the reply, I'll definately try to get everything, I'll know better once i've removed the rocker itself but it appear that i've got 90% of it with just a chunk missing, which i'm hoping i'll find when I do some more work on it...
Don't think it was around the adjustment nut, the bit that broke off is the bit that runs along the cam lobe, so the opposite end to the valve/adjustment stuff, as to why it broke I can't see any reason for it really...
Hmm, thats a bit annoying, was kinda hoping it'd be a nice easy fix, ah well guess taking the head off can't be that hard ;)
Fushion_Julz
yeah, head off isn't too hard-a job...You'll have the bonus of a nice new head gasket and it will be worth changing the head bolts for the latest types that don't stretch and change the cambelt, too...
Your pics show it broken between the valve stem and the rocker shaft...as in that is where the bits have come from...
However, you don't have a close-up of the "nose" that rests of the camshaft so can't comment if that is damaged...
It appears, though, that while the actual parts missing from the rocker are the pieces that broke off, I would say the reason that the valve isn't opening properly is that there is a crack around the adjustmnet nut thread...This may have been the cause of the breakage but it could easily have been as a result of the other part snapping..
Since it is most likely you are gonna have to remove the head, when it is off, do a leak-test on the valve sealing...with the cam removed and valves closed, pour a bit of petrol or paraffin into the combustion chamber in the head (head upside down on the bench, obviously)..the liquid should not drain away with any appreciable speed...If it does, the valve isn't seating properly and you may want to replace that valve, collet and spring and grind in properly before re-assembling it all...
NoSkill
Fair enough, I was told it had the timing belt replaced recently anyway but got no proof so i'll replace that anyway,
Leak test seems easy enough, just need to get a bit of petrol from somewhere...
Assuming all the valves are fine, i'm thinking this is the list of stuff i'll need to buy:
Rocker cover gasket
Head gasket ( Would a 'gasket set' include both of these or not?)
Timing Belt
Rocker(s)
New set of head bolts
Anything else needed or should that cover it?
Rocker cover gasket
Timing Belt
Rocker(s)
Fushion_Julz
Oil, filter definitely...
Antifreeze would be worth doing, too...
I'd go for the head set...comes with all the O rings and valve stem seals should you need them, too...Rocker and head gaskets will be included together with camshaft oil seals.
IIWY, drain the oil and if there are loads of bits of shrapnel in the oil or in the sump, then it may be worth getting a sump gasket and dropping the sump to clean it out....
Globulator
Any spare metal in the rocker assembly area will drop into the sump - I don't think they'll be a problem.
The head looks quite dirty however - past oil servicing may have been infrequent..
If you do decide to take the head off (not required I think) you may as well grind in the valves etc and do all the relevant rubber seal replacements etc. - and you'll need a new cambelt, seals, waterpump, tensioner, studs etc.
P.S. Go for a new spraybar too (use threadlok), if you replace the cam - read the cam instructions! You may also want to use the proper oil/grease for the cam when you reassemble to prevent dry start-up wear - you'll have to find out exactly what to use tho.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
If you just want to get the car back on the road, I wouldn't dream of taking the head off.
Remove all the adjuster eccentrics, and all the rocker locating clips on the affected side.
Take the radiator out, turn the crankshaft with a 22mm spanner, and push the rockers sideways clear of the valves as each comes loose.
Strip of the distributor cap and timing belt covers and slacken the cam sprocket bolt.
Undo the engine mounts and lift the engine up with a jack and a plank of wood across the sump.
Turn the crank so that the timing marks line up, remove the belt and the cam pulley.
Remove the rocker shaft locating plate (just in front of the front connection for the spray bar), and the rocker shaft should be able to be slid forward until the broken rocker falls off the end.
Put the fresh one on, put everything back together using a new cambelt and idler. Good time to change the water pump if at all suspect as well.
Check the rotor arm and distributor cap are OK before you put them back on.
NoSkill
I'll take a look at the haynes manual to see if it's possible to remove the broken rocker without taking the head off, as I said totally unsure of history so not surprising the oil servicing has been infrequent, and i'll definately be changing it fairly regularly now I own the car...
So if It's possible to get the rocker off without removing the head then all i'll need is:
Rocker cover gasket
Rocker itself
feeler guages to set the valve clearances (which i'll do for all 12)
<edit> and after reading the previous post also need
cambelt, idler and probably water pump
Rocker cover gasket
Rocker itself
NoSkill
Actually, quick question, If I undo all the engine mounts and lift it up, isn't it going to be a bit of a pig to put back on/to the mounts?
Also another request of whether the above list is correct or not, going to be going to get the parts early tomorrow morning and can't really do another trip till a week tomorrow, pretty please :p
