leaking inlet manifold gasket
kam325itouring
Post Sun Oct 22, 2006 7:54 pm
hi all
my inlet manifold gasket is gone!!!! :cry: its sucking in air from nearest to the thermostat.... got a couple of questions. how easy is it to do if i do it myself, or if i get it done how much am i expecting to pay??
also if the manifold is comming off i was thinking of fitting a bbtb on too even though the car is not chipped.... comments please. anything else i should do??
kam
Post Sun Oct 22, 2006 8:02 pm
Inlet manifold gasket is only a nuts and bolts job. Nothing difficult.
Renew the rubber O rings top and bottom on the oil drain tube, and tie the spring down with something like fishing line when you refit the tube.
1/4" socket set is usefull to get at some of the nuts.
kam325itouring
Post Sun Oct 22, 2006 8:07 pm
the head was done a year ago i think they were done....
Post Sun Oct 22, 2006 8:18 pm
Still change them again, they're only pence to buy.
This is looking like deja vu. An engine I fitted in one of my cars was fitted with a brand new cylinder head (engine came from a right off, crashed 2 weeks after the work!), and fifteen months later this front gasket failed.
The front nut is partly hidden behind the water elbow, and when I dismantled it the front nut was nowhere to be seen, in spite of all the others being nylocks. Same muppet who fitted the head also left one of the water pump bolts loose, as I found out six months later again!!!
