M3 Cluster Vs Normal Cluster
6potWil6pot
Post Tue Mar 22, 2005 6:20 pm
Is it possible to chop and change clusters? I fancy getting an M3 one and swapping the speedo over so it shows mph on the proper UK dials (the real reason is im after the oil temp gauge but i might aswell make it perfect while im at it).
Also would the mileage creep up in kilometers instead of miles still? I assume it would...
Demlotcrew
Post Tue Mar 22, 2005 7:04 pm
6potWil6pot wrote:but i might aswell make it perfect while im at it
:lol:
6potWil6pot
Post Tue Mar 22, 2005 7:09 pm
Well i'll obviously pratice with smashing up a normal cluster first before going to work with a screwdriver on the M3 one!
Unless youve got any bright ideas or fancy doing for me? :o
Karan
Post Tue Mar 22, 2005 8:02 pm
:lol:
LOL
harsh!
Demlotcrew
Post Tue Mar 22, 2005 9:25 pm
6potWil6pot wrote:Well i'll obviously pratice with smashing up a normal cluster first before going to work with a screwdriver on the M3 one!
Ill do it for you!
Post it up or come up and see me.
Andrew
6potWil6pot
Post Tue Mar 22, 2005 10:31 pm
:tongue: Cool!
I'll be having that one off ebay hopefully then!
Might aswell grab the bits i need for a temp sensor tho if im gonna do it!
Probably wont be until June anyhow, kinda busy until then!
Karan
Post Tue Mar 22, 2005 10:58 pm
andrew fancy knocking somehthing up for project 'beast'
needs 7.5krpm limiter and oil temp and a 180mph speedo from the e34 m5 would be nice if it could fit somehow....
cheers
Karan
Post Wed Mar 23, 2005 7:36 am
where there's a will there's a way..... :cool:
Demlotcrew
Post Wed Mar 23, 2005 11:06 am
I found an easy way to get the temp sensor in to the engine, some of the M30 oil filter caps have provisions for a temp sensor. So to find on in a scrappy!
Andrew
