318is with s14 exaust manifold
A3T
Post Sat Oct 21, 2006 9:15 am
Is it worth to change it against the stock one? Doest it even fit right on or does it need modifications?
Bye
E30Mark
Post Sat Oct 21, 2006 9:29 am
I would guess it would never fit.
The S14 manifold will be designed for a LHD car, it will hit the steering on a RHD car. Plus i reckon the port sizes & stud pattern on the head is probably different.
The original M42 manifold isn't too bad, apart from they crack !
Welcome by the way :D
PM for details
A3T
Post Sat Oct 21, 2006 2:41 pm
TNX :wink:
I have the LHD car :wink:
I also think the stud pattern is different, but you can see it on one of your forum members engine. White e30 318is and the owner is Tim or similar.
Bye
Pal318is
Post Sat Oct 21, 2006 5:00 pm
The normal m42 one is pretty decent imho. But there are some decent one's available out there.
Pal
Also that's the 1st lhd iS i've seen 8O
Pal
Image[img]http://Image
e21Jason
Post Sat Oct 21, 2006 9:41 pm
I have a stripped M42 & S14 in shed and the manifolds do not line up at all
Jason
