dim headlights
eltel
Post Fri Oct 20, 2006 2:18 pm
hi there...
my 1988 325 has of late been suffering with dimmer than usual headlights..the main beam is fine.
both bulbs have been replaced but are the same.
i know that the alternator is only kicking out about 12.5 volts which is a bit low but the mains should also be affected should'nt they???
Post Fri Oct 20, 2006 9:16 pm
Unclip the back cover on the headlamps and measure the voltage 1/ directly across the wires to the bulb, and 2/ from the wire to the bulb centre lead to battery negative (or good body earth).
Haven't fitted 24V bulbs, have you?
eltel
Post Sat Oct 21, 2006 5:49 pm
no just normal bulbs fitted... if earth is ok and bulb gets less than 12.5 v then its prob the alternator isnt it...thanks for the help
Post Sat Oct 21, 2006 6:00 pm
Alternator needs to putting out about 14 volts or so. Check for any voltage between the alternator alloy case and the battery negative. Corrosion can build up in the alternator mountings.
I've seen more than one perfectly good alternator thrown away because of this, and of course, a new alternator always cures the problem, because fitting it sorts the corrosion.
kam-325i
Post Sat Oct 21, 2006 6:10 pm
Mmm....
Ok...im having a thick moment.....should there be any voltage between alternator casing and battery - ?
Post Sun Oct 22, 2006 1:19 am
kam-325i wrote:Mmm....
No, shouldn't be any significant voltage. That's the point!
mrLEE30
Post Sun Oct 22, 2006 11:15 am
if you are getting funny readings on the above test make sure your meter is set to DC volts not AC! sometimes overlooked and can result in strange readings!
mrlee
eltel
Post Wed Oct 25, 2006 3:47 pm
thanks for all the advice...still havn't had time to check it yet ..but i will :mad: !!!
