Post
Tue Mar 22, 2005 2:41 pm
Toby's right. If it's a 3.5, it'll be motronic, and he's right about the dizzy, the cap and rotor arm are crucial to good running on these engines.
Plus if it doesn't run, check the sensors that plug into the bell housing, remove them (gently) clean the contact faces and replace them, and clean the electrical contacts thoroughly, if one of the sensors isn't sending the right info, the car will either not fire at all, just turn over, or will not rev over 1000rpm. The CSV also clogs up, so should be cleaned out, other than that I'd turn it over to get some oil moving, then have a go at firing it up.
There's also the dme relay that sits on the bulkhead (effectively in front of the driver?) and the pins do corode, so clean these up carefully. Lastly, check the ECU isn't soaking wet, it sits behind the speaker grille in the drivers footwell, if it is, dry it out, and reconnect.
