REplacing fog bulb
E30_droptop
Hi, i might sound a bit dumb.. BUT how do you replace a fog bulb on a E30 convertable? i cant get tha front plastic bit off 2 get 2 tha bulb? Thanks
Pal318is
There are is a screw underneath the fog, inside the front valance. Check that out, once unscrewd you should be able to get the bulb. it's not done from the front of the fog.
HTH
Pal
HTH
Pal
Pal
[img]http://
[img]http://
Hyperion
Pal318is
Or you can take the fog lamp out by removing plug 7 and then the screw behind it, dont need to lye on the floor then
jcjdavis1
Hi When you remove plug7 is it screw No6 you take out as I am retro fitting mine and was wondering what screw to use?
