M3 LSD on a 318iS???
MrBroon
Mon Mar 21, 2005 8:40 pm
Whats the standard LSD diff gearing for a 318iS? I'm looking at getting an M3 diff which is 3.25 but wanted to know if this is correct.
Cheers.
James Westwood
http://www.bmbits.co.uk BMW Parts at upto 50% off dealer prices
IT Security solutions Scotland
Ant
Retired Team Member
Retired Team Member
Mon Mar 21, 2005 9:07 pm
the M3 diff is way to high for the 315iS, 325 would struggle unless fitted with an e39 or early dogleg box
in short, dont do it !
if its cheap, buy and stick on ebay :wink:
6potWil6pot
Mon Mar 21, 2005 9:14 pm
Yep, ive got an M3 LSD in mine cause it has the E39 box.
I think a 318iS is a 4.10 diff stock so thats a huge ratio difference! :eek:
Mind you i think a 4.10 LSD is even rarer! A few of the 318iS boys seem to have gone for the 3.91 325i Sport LSD if im not mistaken.
MrBroon
Mon Mar 21, 2005 9:18 pm
Right so lower number equals lower RPM per gear is that right? Therefore the gearing will be far too tall?
James Westwood
6potWil6pot
Mon Mar 21, 2005 9:21 pm
Yeah i think so, it depends on the gearbox ratios too! E.g the 3.25 LSD has ratios that are just about right on my setup, but wont be doing yours much good for its acceleration. I had a 3.46 diff at one point and first gear was useless and 5th would accelerate like a monster! Didnt make for a calm drive tho!
Jimbob
Mon Mar 21, 2005 10:29 pm
A cause for concern with a 2.7 running a 4.10 lsd then..
:lol:
kevin316i
Tue Mar 22, 2005 9:28 am
4.10 is standard ratio for the 318iS. You could go for either a 3.91, 4.10 or 4.27 ratio LSD and these are available as small casing diffs. The big casing diffs will fit but you are carrying around extra weight for no extra benefit.
johnono
Tue Mar 22, 2005 9:31 am
whats a good combo for a 2.l then?
MrBroon
Tue Mar 22, 2005 6:01 pm
Thanks, much appreciated.
Are they a job and a half to fit myself?
James Westwood
