cold start prob plus fuel gage prob
blondie
Post Sat Oct 14, 2006 11:40 pm
hello,i actually have a 325i bmw, i have a problem with it the problem being,when its cold it doesnt like starting,its lumpy and stays like it until warm.i have changed the fuel regulator,plugs and cap rotar arm none of which have helped,cleaned out the throttle body and had the co levels set up properly,any ideas?
i have also had trouble with the fuel gauge,its not reading acuratley,i have changed the gauge itself and the senders,checked feeds to the senders, one of which is an earth and one is a dim live when the ignition is off.when i turn it on i still have the earth but the dim live is dead,is the dim live supposed to be an earth?hope thats better please help,dave.
EThreezero
Post Sat Oct 14, 2006 11:49 pm
:eek: jeez mate take a deep breath and start again :D :D but sounds like a question for Brianmoooore, our resident electrical guru.
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
EThreezero
Post Sat Oct 14, 2006 11:50 pm
Oh and sorry mate, Welcome to the zone :thumb:
Post Sun Oct 15, 2006 12:43 am
I'm no linguist. Only understand English, and perhaps a little French.
EThreezero
Post Sun Oct 15, 2006 1:14 am
Brianmoooore wrote:I'm no linguist. Only understand English, and perhaps a little French.
:lol:
EThreezero
Post Sun Oct 15, 2006 1:17 am
blondie wrote:hi there i have a 351i
Ment to say, whats this??
blondie
Post Sun Oct 15, 2006 7:50 pm
havent had a drink this eve have re-written hope its a bit clearer!
Post Sun Oct 15, 2006 8:26 pm
Engine problem sounds like a classic case of "blue temp sender" syndrome.
On the top of the water outlet elbow (top front of engine) there are two sensors, one with a brown socket, and one with a blue. The blue one tells the engine ECU if the car is cold or at running temp.
I think yours is telling the ECU that the car is hot when it's actually cold.
Can be a bit difficult to get a tool on to unscrew it, but other than that, an easy job. IIRC, the tool kit spark plug spanner will fit it.
You've lost me a bit with the fuel gauge. What's "dim live"?, and how many level senders do you have?
blondie
Post Mon Oct 16, 2006 7:55 pm
thanks mate changed that still has prob? doing my head i have been using test things with a power prob which tells you live and earth when ignition is on or off thanks dave
Post Mon Oct 16, 2006 10:31 pm
I think I'd check that the throttle position switch is working properly, check all the gaskets on the inlet side (spray easystart or similar near the gaskets on a closed throttle. Any leak will draw in gas and the engine will rev), and then suspect a leaking injector.
Is any plug a different colour from the rest?
Forgotten one common trouble spot - There's a round plug and socket fixed to the metalwork under the inlet manifold. Check the connectors in this are all bright and shiny.
blondie
Post Wed Oct 18, 2006 6:07 pm
ok mate thanks for that i will cheak them and let you know cheers for the help dave
