Rear Wheel Bearing Fix?
Pal318is
Post Thu Oct 12, 2006 6:35 pm
Guys/Gals,
Just wanted some info on how to replace the wheel bearings on the rear of my iS?? Not done this before, so a little unsure, what the best way/method to do it.
Any help appreciated.
Pal
Pal
Image[img]http://Image
Pal318is
Post Thu Oct 12, 2006 8:25 pm
Any1 8O
Pal
Pete159
Post Sun Oct 15, 2006 8:49 pm
Have a look at the article on http://www.bmwe30.net/ - Articles and tips section - Suspension and steering - Replacing a rear wheel bearing. At steps 3 and 4 you can use a slide hammer instead, to remove drive flange and then what is left of the bearing, but this does leave part of the inner race on the drive flang that has to be removed with a puller.
E30Adam
Post Sun Oct 15, 2006 8:52 pm
I'd seriously consider just paying a garage to do this job for the world of grief it will give you.
I'll attempt most jobs (including removing and rebuilding engines) on my car but this one I left to the garage.
Andy335Touring
Post Sun Oct 15, 2006 9:06 pm
I wish i knew what i was letting my self in for other wise i wouldn't have started this job as it's bit me in the arse
http://www.e30zone.net/modules.php?name ... ic&t=47965
