325i tappets i think
seanboy
saw a cheap e30 325i off ebay. knew it was quiet tappety but thought little project?? bought it Ԛ£270.00 bk alpina 17" alloys on her with good tyres.drove it 120 miles home and at some points nearly touching 130mph in it, good old e30's. no pulling in steering, or juddering in brakes.
But to the point thought: i read a few topics and printed off the e30 valve adjustment article and followed that well. but problems still there, loads of noise. i've come to the conclusion the tappets need replacing? how much to buy tappets and do i have to strip the whole cylinder head? can anyone give me any tips or got a brief guide? thanks very much
surj
did you reset tappets when cold and sometimes they need doing again also on some of the engines ive had all it really needs is a nice oil change and an oil change is a defo if the cars been standing
seanboy
by reseting tappets do you mean valve adjustments because i reset these cold. i havent changed the oil yet and will get round to doing this soon, it does seem really thin
diamondblacke28
a good mecanic who races motorbike for fun told me you can remove the rockers. and if they are worn on the surface that runs against the valve stem you can file a new surface.
hope its of some use to you
seanboy
think ill put a new spray bar in, change oil and see if this makes a difference.
surj
yes i mean valve adj. ive brought a few m20s a straight away thought the tappets need setting but after a oil change its run fine (the cylinder heads way of saying i need a oil change) but if is is the tappets has far as i know i think the head will have to come off as ive tried removing the rods with the head on the car and i couldent do it that way has far has i know i think the rods are handed as well so dont mix em up (by rods i mean the two rods that the rockers are on
surj
just thought could also be a warn cam but more chance being the rockers
DaleR
Rockers wear out quicker than the cam on the m20, also Clean out the oil spray bar!!!, or replace it!!!.
Rockers can be changed without removing the head.
seanboy
Found a invoice with the history describing a new head was put in 30,000 miles ago Ԛ£1,600 in total.but it depends on how good the mechanic is i suppose. going to order spray bar today and change oil at weekend
seanboy
also there is a 2.5 / 2.7 round stamp above the manifold below the plugs towards the right of the engine. this dosent mean anything special does it? that clocks wrong up there next to the date!! going to get some zzzzz's
seanboy
Changed oil and filter cleaned out spray bar still very tappetty. So I'm thinking of replacling the rocker arm bushes if there worn like it say's in haynes. I hear some say replace the rocker arm's do you mean what haynes is saying? not an expert but if you take the rockers off would it be the best time to change the tappets? cheers
EThreezero
Are you sure its not noisy injectors your hearing mate, i fell for this with my first 6-pot.
i know its not your first but just a thought, or juat tell me to be quiet
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
seanboy
The noise i'm hearing is really tappetty, she's idling at about 1200 rpm and proper tappetty when i force it down to where she should be idling you still hear it but not so bad. Did you get this when your injectors went? cheers
EThreezero
All i can remember was that the noise sounded identical to the sound of noisy tappets, to the point it had me a tappet adjusting/renewing feckin madman. Gawd knows how many times i tried to set them, ended up buying all new. Still there. I know the 2.5's have a slight tappet noise anyway but this was major. It was an older BM enthusiast from along the road from me at the time that told me to try different injectors and yup he was right 70% of the noise was gone and it was just the usual slight ticking from the injectors and the usual noises from under the rocker cover.
Injector noise will stop immediately the ignition is cut. Tappet noise will continue untill the engine stops turning.
seanboy
How much are a set of injectors and is it an easy job?
EThreezero
Yup correct, i just never clicked to this back then. The amount of times i started and stoped the damn thing youd think i'd have realisedBrianmoooore wrote:Injector noise will stop immediately the ignition is cut. Tappet noise will continue untill the engine stops turning.
EThreezero
I just obtainedsecond hand and they still cost me a tenner each if i remember. Not inexpensive items im afraid. Easy to fit however, swap could be done in an hour.seanboy wrote:How much are a set of injectors and is it an easy job?
seanboy
Ill check this tomorrow. would this be effecting my rpm idle its about 400/500 higher than normal?
EThreezero
Dont think so, my white tourer sits a tad high also but if i put another ecu in it sits bang on where it should but does'nt run as goodseanboy wrote:Ill check this tomorrow. would this be effecting my rpm idle its about 400/500 higher than normal?
seanboy
your tourer an alpina
EThreezero
I wish
one day
seanboy
I had a black 325 tourer slightly lowered don't know exactly how much (previous owner) but they look good with its 17" alpina rep's.
EThreezero
Touring's the only way to fly IMO
Hope you sort that problem out dude
seanboy
[quote="Brianmoooore"]Injector noise will stop immediately the ignition is cut. Tappet noise will continue untill the engine stops turning.[/quote]
Tappet noise continues until after the engine stops turning. So it should not be injectors but tappets or rocker arms? so I suppose i'll have to strip the head to get to the tappets?
Can be changed without removing the head.
jmc330i
AFAIK its just a normal 2.5 head here in the UK (same as mine). Its just the head was also used on the 2.7s.seanboy wrote:also there is a 2.5 / 2.7 round stamp - this dosent mean anything special does it?
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
seanboy
Wondering if someone would be able to give me an idea without removing the head? cheers
About what?seanboy wrote:Wondering if someone would be able to give me an idea without removing the head? cheers
seanboy
[quote="Brianmoooore"][quote="seanboy"]Wondering if someone would be able to give me an idea without removing the head? cheers[/quote]About what?[/quote]
tappets or rocker arms, looks like the rocker arm shaft wont come out while in the engine bay.cheers
Although I've never tried it with an engine still in the car, I think it can be done with a jack under the sump and by loosening the engine mounts.
seanboy
So doing this do you mean its raised at an angle and you can take out the rocker arm shafts and so on? spent a little time on her today and took the ehaust off, removed dizzy cap, large hex bolts holding down cylinder head but there seems to be a lot more work for the begginer? T
hought it would come straight off how wrong.doing this with the engine in
Oh dear, You shouldn't have undone these!seanboy wrote: large hex bolts holding down cylinder head
Head has to come off anyway now, and will need checking and skimming, especially if you didn't undo them in the right order.
Hex headed bolts should have been removed and replaced (one at a time!) by torx headed ones many years ago.
The heads have a nasty habit of breaking off the hex ones and getting punched through the head by the camshaft.
That's what I meant, yes, but I think it's academic now.seanboy wrote:So doing this do you mean its raised at an angle and you can take out the rocker arm shafts and so on?
