The rear valance has a fist sized rust patch and daylight is starting to peep through.
A 10p sized hole on the scuttle panel a couple of cm below the windscreen.
A small hole to the right of the throttle pedal where i stupidly jacked the car up and put the jack stands under there(i thought they were jacking pads) although apart from this it seems structually sound.
And the idle speed is a little high(about 1000rpm).
I will get all these properly sorted out swiftly just at the mo i am getting impatient to get my baby through the MOT.
Any help would be much appreciated.
Thanks, Dan
