head gasket m20 325i
- Brianmoooore
They are torx stretch bolts. If the originals are hex headed bolts, they should have been replaced years ago.
i pulled the head off couple months ago on my 1983 320i and i found that the original bolts were still on, and i used the same again, but you should always use new ones Torx and you d not need to retighten them after the car is hot
