Why is my rev counter not working?
Martin347
Post Thu Oct 05, 2006 1:41 pm
I have just put a 318is engine into a 325i and my rev counter isn't reading correctly. It seems to be reading far too low rpm. Is there anything I can do to solve it or do I need to buy an aftermarket rev counter?
Thanks, Martin.
dazleeds
old skool raver
old skool raver
Post Thu Oct 05, 2006 1:43 pm
did you swap the plug in the cluster for the 325 plug??
if not thats ur prob
www.oldskoolfantasy.co.uk
gcorky
Boost Junkie
Post Thu Oct 05, 2006 1:49 pm
dazleeds wrote:did you swap the plug in the cluster for the 325 plug??
ditto what daz said as you are running 4 cyls instead of 6 ...you need a 318 coding plug.
525 sport
Martin347
Post Thu Oct 05, 2006 2:33 pm
When you say 'plug in the custer'. Which one do you mean?
Thanks, Martin.
dazleeds
old skool raver
old skool raver
Post Thu Oct 05, 2006 2:43 pm
on the front of the cluster on the right hand side youll see a white plug bout 2inch ya need to put the plug for the is engine in to there
Martin347
Post Thu Oct 05, 2006 3:13 pm
Sorry, I might be being abit thick here :o: but what do you mean by 'the cluster'.
gcorky
Boost Junkie
Post Thu Oct 05, 2006 8:41 pm
Martin347 wrote:Sorry, I might be being abit thick here :o: but what do you mean by 'the cluster'.
take out trim from in front of your speedo/revcounter etc,and on the bottom right is a plug in module......aka coding plug..
525 sport
Post Thu Oct 05, 2006 9:11 pm
The iS four cylinder engine produces two pulses per rev to drive the tacho; the 325i six cylinder engine produces three pulses per rev.
All E30 instrument panels are the same (except M3 and some early ones) so information on the number of cylinders and fuel tank capacity is contained in a separate plug in unit on the front of the instruments, behind the trim panel just under the instruments and above the steering column.
Martin347
Post Fri Oct 13, 2006 9:02 am
Swapped it, everything is working fine now. Thanks for everyones help.
