my central locking is being temperental and keeps blowing the thermal fuse. what would cause this?
a bit of background...
the central locking had always worked faultlessly until at santa pod where it packed up!
upon inspection i found the central locking control box was positioned upside down and had filled with water! (my fault i reckon as i'd had it out while changing the doors a week previously....). a few of the resistors on the end had corroded so i replaced these, cleaned it off and dried it all out. when i refitted it, all was fine again but a day or so later it stopped working. it now just blows that thermal fuse after a day or so every time.
is this likely to be a problem with the control unit itself or something else? the wiring and solenoids on the new doors were all transferred from the old ones and was all in perfect condition.
