Hi all
I have a 316 2 door on an '88 plate and I want to convert the front windows to electric.
I have the centre console with switches and I have most of the wiring loom necessary.
Has anyone completed this before and if so were there any problem areas to watch out for and do you have any list of all parts needed please?
I understand I will need 2 door switches also for when the motors reach their extremities of action.
I thought that the wiring for this would be included on all 2 door models so that you can have the option but I can't see it anywhere.
I would appreciate any and all help given.
VQ
Electric window installation
votivequagmire
There are two different kinds of non interchangeable (different glass) window mechanisms used on E30s, depending on age.
'88 is probably the later type, but could just possibly be the early type.
No door limit switches are involved. The motors just stall at the end of their travel. Crude, but that's the way they are.
Early type mechanism is a flexible cable running in a large S shaped tube; later mech is a gear and toothed quadrant arrangement.
votivequagmire
My model is with plastic bumpers so will that make it a later model?
I hope so as the tooth and gear arrangement sounds eaiser to fit.
I came across the earlier type in an old door I had recently for a quarter light, gave up trying to remove it!
I got the wiring loom from a four door model. It will be ok to use yes?
I just dont have the two rear windows to attach but it should still work wont it?
I have electrical experience and a few circuit diagrams but it isn't exactly clear on some of the parts needed. F'rinstance the relay type or number.
Any ideas where I would be able to get a better list of items needed?
The changeover for the windows was a bit later than the facelift changes, I'm afraid. I have two '88 318i s, and one is early windows, the other late.votivequagmire wrote:My model is with plastic bumpers so will that make it a later model?
The later electric window mech. fitted the early door frame, but the glass had to be swapped as well.
Four door loom is fine - all four doors with electric fronts are fitted with this loom, even if the car has manual rears.
You need to fit relay K5, (which is an ordinary four pin relay like most of the others in the fusebox), and fuse 17, 30A.
There is another relay, complete with a small sub loom fitted at the back left corner of the glovebox, that is fitted to UK cars, which allows the windows to work with the doors open and the ignition off.
Only other thing you need is the overload cut out switch, which fits in the console just in front of the right hand window switch.
The standard window loom on an E30 is all incorporated with the central locking loom.
votivequagmire
Yeah, I saw two relays behind plastic cover in glovebox. Blue and an orange one i believe.
I was taking the loom out and thought I might need them so grabbed them the same time.
I'm still waiting on the mechs at the moment. The guy at the scrappy which I got the loom from etc. is supposed to be searching through a whole load of mechs for the right pair for my car but I don't think his heart is in it somehow as its been 2 and a half weeks now and still nothing.
I still have a couple of other wreckers yards to visit.
Maybe I will find a 3 series around about my year, complete with mechs and windows if needed.
The overload switch, if it is the same dimensions as the switches, with a red band visible when switched off, I already have as part of the centre console and handbrake cowling deal I made for the princely sum of Ԛ£5, with one switch missing.
The loom I removed (But damaged the rear loom feeds on removal) I paid Ԛ£3 for.
So if I can get the two mechs for around a tenner each then I'll be laughing.
Just had a bit of a nasty incident yesterday
A husband and wife in their 70's driving a yellow, motability Peugeot 1007 decided to give my black E30 a nice go faster stripe along the nearside door and rear wing using their front wing.
As I was traveling along towards a crossroads traffic lights, with three lanes (one on right turning right and other two straight on), I was moving up the middle lane to go straight on when before I could do anything, he came across the lane separators and clipped my car from door to rear wing.
Luckily there was a copper behind who not only saw the accident, it turns out he had followed said Peugeot for the past mile and advised the driver that he believes he is not safe to drive.
Some elderly drivers should be retested after a certain age and if they fail on major faults should have their licences taken off them for good.
Of course they were with Saga insurance and blurted out the usual "we've never had a crash before and we've been driving for 50 years" etc.
So now I have to get quotes for repairs and get an insurance form filled out.
This above all things I did not need.
My baby is injured
She's showing her age in a few places but a good solid car with minimal rust found.
By the way thanks for your advice Brian. Sorry for my inane drivvle in between.
My baby is injured
eko
- Old timer
votivequagmire
i got some motors if you want them?
votivequagmire
Well I wont be able to make any reasonable offers until the end of this month but I would be interested. If their compatible with my set up as well.
I assume you've read the previous threads of this? I wouldn't want to go to all the trouble and finding I need something else.
Are they the toothed ones?
eko
- Old timer
they are from a 1990 318is,should be the same as long as yours is plastic bumper
Don't wish to worry you, but you should be aware that it takes a very, very small amount of damage on a '88 316 for it to be declared an insurance total loss, so approach your accident negotiations with this in mind.
Relays behind the glovebox may not be the right loom. '88 cars had dim dip driving lamps (outer headlamps on at reduced brightness with the lighting switch in the first position), and there were two relays behind the glovebox for this.
Also early ABS cars are supposed to have a relay here as art of that system.
votivequagmire
Well the other insurance company said it was uneconomical for them to repair it and have given me a cheque for nearly £800.
And I get to keep the car.
Think I may sell this 316 and get a 320i instead.
One on ebay looks nice.:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
Anyone on here selling a 320i 4 door E30 around '88/'89?
