Non starter after removing OBC ?!!
Jerran
Post Sat Mar 19, 2005 3:44 pm
Just removed the OBC and wiring from my 320,though now it doesn't want to start ?! Anything obvious I need to check ? I only removed the wires that I needed to,ECU still plugged in etc etc Prior to removal it wasn't using the OBC immobiliser code thing so it can't be that ? Anyone experienced this before ?
Ant
Retired Team Member
Retired Team Member
Post Sat Mar 19, 2005 4:07 pm
you need the plug to bridge the two green wires at the SE connector by the glovebox dude.
look @ the plug you removed from there and link out the corresponding pins on the socket M8
HTH
Jerran
Post Sat Mar 19, 2005 6:36 pm
Mate you're a star ! Opened glovebox,found connector,located some dodgy old bit of wire,shoved it in,turned key & six cylinders burst into life ! Result.
Any pics of your wheels ?! Mine's in members rides I think.
Kedge
Post Sat Mar 19, 2005 6:47 pm
I've got the opposite problem, just fitted my OBC, stared my car up and it won't turn off, turn the keys and remove them and its still running :mad: !
Have to stall it to turn it off, electrics go off though. Any ideas?
Instagram - Kedge85
Jerran
Post Sat Mar 19, 2005 6:59 pm
Bugger ! I wish I could help,it could well be something to do with the green plug Ant mentioned for my post as that must be connected to the ignition somewhere hence my failure to start.
Kedge
Post Sat Mar 19, 2005 7:14 pm
Pretty sure everthing is in the right place, both the plugs off the OBC'x loom are in the control box.
Guessing i've done something to the wiring from the ignition barrel while doing the indicator stalk but can't find any lose wires :roll:
Instagram - Kedge85
Cloggy Saint
Post Sat Mar 19, 2005 7:17 pm
2 plugs to the control box? mine only had one and the obc works ok without it. I'm guessing the relay box is only required for the code function.
Kedge
Post Sat Mar 19, 2005 7:25 pm
These two plugs, green wire and red wire behind the glovebox. Yours might be different if its the 6button one in your sig.
Instagram - Kedge85
Jerran
Post Sat Mar 19, 2005 7:52 pm
That gong that looks like a horn,where is it on the car ?! Should it be above the drivers legs ? Can't find the one on mine that I've just removed though the panel above the drivers knees was missing. I want to make sure I've got the full kit when I come to sell it
Simon
Post Sat Mar 19, 2005 8:08 pm
Jerran, the thing that looks like a horn, is a horn, it's what sounds if the CODE function is entered wrong so many times.
The gong is a small black box (lower right of the above pic) that looks somewhat like a speaker, and should be located aboe the drivers knees.
Kedge
Post Sat Mar 19, 2005 8:24 pm
How do you find out the code and then enter it
Instagram - Kedge85
Cloggy Saint
Post Sat Mar 19, 2005 8:36 pm
Kedge wrote:These two plugs, green wire and red wire behind the glovebox. Yours might be different if its the 6button one in your sig.
i recently fitted a 13 button unit. The wires you refer to are for the code feature which i didn't bother with.
To enter a code you must turn the key to psition 1, press code on the obc and enter a 4 digit number. Then turn ignition off. When sarting the car turn the key to position 1 or 2 and then punch in the code number. You get 3 chances to get it right before the horn sounds.
Jerran
Post Sat Mar 19, 2005 8:44 pm
I'll have another look for the gong tomorrow,think it's missing from the 320 I'm breaking. I think I'd crap myself if the someone had wired mine up and replaced the gong for a horn !!!
Kedge
Post Sat Mar 19, 2005 8:56 pm
Cheers datourer, think i'll unplug those then as i aint bothered about the code function and haven't fitted the horn.
Instagram - Kedge85
Cloggy Saint
Post Sat Mar 19, 2005 9:34 pm
yeah, i don't think anyone bothers with this function.
Kedge
Post Sat Mar 19, 2005 9:48 pm
Just been out and unplugged those wires, and hay presto my car now turns off! :D
Instagram - Kedge85
Cloggy Saint
Post Sat Mar 19, 2005 10:12 pm
result!
