oil pressure light
blingsta
Boost Junkie
Post Sat Sep 30, 2006 7:26 pm
me again! what does it mean when oil pressure light comes on at low revs or on idle?? does it mean that oil isnt circulating? and how much damage can this cause?
Steviec
Post Sat Sep 30, 2006 7:41 pm
Sounds familiar! Mines the same, is yours smoking?
<a><IMG></a>
Post Sat Sep 30, 2006 7:46 pm
Oil light on is not normally good news, but try a new switch before you panic too much.
blingsta
Boost Junkie
Post Sat Sep 30, 2006 7:57 pm
mine started smoking and running very badly on way home last night together with overheating and head gasket!!!
Post Sat Sep 30, 2006 8:54 pm
Just keep the oil pressure switch and fit a new engine to it.
Sooty
Post Sat Sep 30, 2006 8:57 pm
:rofl: :rofl:
blingsta
Boost Junkie
Post Sun Oct 01, 2006 3:03 pm
so seriously.. does block need to be changed now, or can it be saved?
Post Sun Oct 01, 2006 4:19 pm
It can be saved if you throw enough time and money at it, but oil pressure light on, overheating, smoking, bad running......
I haven't seen it, so I can't say from here, but sometimes you've just got to know when to give up!
blingsta
Boost Junkie
Post Sun Oct 01, 2006 5:45 pm
that is a very good point Brian, but i thought it would be something simple such as oil not flowing properly due to the bad running? and once the engine is flushed with engine flush together with the cooling system it should solve problem!! Ive had the head off and inspected it thoroughly, No signs of head gasket failure or cracks on head..???
Chris-W
Post Sun Oct 01, 2006 5:46 pm
Have you had the cam out of the head?
blingsta
Boost Junkie
Post Sun Oct 01, 2006 6:39 pm
NO, but ive inspected as closely as i can, and no cracks under the cam...
Post Sun Oct 01, 2006 6:44 pm
You won't see them on the rough cast metal - 0nly as a faint grey line across a cam journal.
Chris-W
Post Sun Oct 01, 2006 6:45 pm
They like to hide underneath the cam, there's no way you'll spot them in a fully built head.
Post Sun Oct 01, 2006 6:46 pm
Beat ya to it!
Chris-W
Post Sun Oct 01, 2006 6:48 pm
Can't type as quick, clearly. Plus I was distracted. And the cat ate my keyboard.
blingsta
Boost Junkie
Post Sun Oct 01, 2006 10:57 pm
cheers guys...i find it easy enough to change the head gasket, but i dont know how to take the cam off, any tips for me? is it easy, and i take it tappets will need re-adjusting when put back together?
