piston movement??
blingsta
Boost Junkie
Sat Sep 30, 2006 7:24 pm
Can anyone tell me how much movement you can expect from a piston? i mean while the heads off and you try to move it from side to side? reason i ask is that i changed the piston rings about 1000 miles ago and while ive had the head off ive checked the pistons for movement and i could physically move them from side to side!!! but i wasnt getting any smoke on idle or on drive before head came off. is this normal?
maxfield
Sat Sep 30, 2006 7:30 pm
There shouldn't be no movement.
blingsta
Boost Junkie
Sat Sep 30, 2006 7:34 pm
Hmmm.. ive got a bit of movement on all of them! :eek:
Sooty
Sat Sep 30, 2006 7:55 pm
Sorry m8 but your wrong :roll: .
If there were no clearance at all between the pistons & bores, then how would they be able to move up & down?
The actual piston to cylinder clearance will depend upon wear & usage, etc, but should be:
New 0.02 - 0.05mm (.0008 - .0020 in)
Wear limit 0.15mm (.0060 in)
Measurements are usually taken 10mm from the top & bottom of the cyl bores & around the circumference of the piston in line with the gudgeon pin, so trying to measure the gap around the top land of the piston is a waste of time.
As long as you can see the crosshatching of the hone marks on the cylinder walls & your not burning oil then you should be alright. :)
HTH m8
Iain S
miamistu
Sat Sep 30, 2006 7:56 pm
There shouldn't be a vast amount of movement, but there will be a clearance from the piston to bore wall which gets bigger the colder the engine.
That's why we have piston rings, to take up the gap!
maxfield
Sat Sep 30, 2006 7:58 pm
When i did work experience the mechanic there said there should be no movement :roll: So he must be rong.
blingsta
Boost Junkie
Sat Sep 30, 2006 7:59 pm
Sooty, whats the crosshatchings on the hone marks look like??
Sat Sep 30, 2006 8:03 pm
blingsta wrote:Sooty, whats the crosshatchings on the hone marks look like??
If you can see them, you'll know why they're called cross hatching.
There's normally a perceptible sideways movement in a piston on a cold engine.
Martinaston
Sat Sep 30, 2006 8:04 pm
Just check to see if the bores have gone oval if they have then its best just to get a new block.
If they are still ok then check they are not beyond the maximum wear limit.
There is NO nucleus.
Sooty
Sat Sep 30, 2006 8:19 pm
When i did work experience the mechanic there said there should be no movement So he must be rong.
Yep !!!!!!!!! :roll:
He's only going to be able to check that with a bore gauge m8. Not the sort of instrument found in your average cantilever toolbox :)
Read my paragraph about measurements again & ask yourself how he's going to do that with the pistons in place.
Demlotcrew
Sat Sep 30, 2006 8:23 pm
Remember that you should measure the piston size about a third of an inch from the skirt.
Most pistons rock at TDC.
Remember that the top (crown) of the piston expands more because the metal there is thicker.
But i agree with Sooty, the specs he gave are spot on.
Andrew
kam-325i
Sat Sep 30, 2006 8:41 pm
Some movement in the pstions at TDC on a cold engine is to be expected, dont forget, metal expands when hot....
bigkev
Sat Sep 30, 2006 11:08 pm
the alloy pistons have a greater rate of expansion to cast iron or steel liners/block so they can not be the same size hence the slight movement this is why most engine wear takes place when cold as the pistons rock slightly until up to temp
Sat Sep 30, 2006 11:17 pm
bigkev wrote:the alloy pistons have a greater rate of expansion to cast iron or steel liners/block so they can not be the same size hence the slight movement this is why most engine wear takes place when cold as the pistons rock slightly until up to temp
Engine wear takes place when cold because that low octane petrol stuff most of you run your cars on condenses out on the cylinder walls and washes the oil film off. That's why petrol cars need a richer mixture when cold and LPG cars don't.
chu346
Sun Oct 01, 2006 9:59 am
Would 97octane be better?
Sun Oct 01, 2006 10:27 am
Not in the slightest. Unmodified E30s cannot gain the slightest advantage from using any fuel with more than the minimum octane rating required to prevent detonation.
reggid
Sun Oct 01, 2006 11:07 am
the reason for a rich cold mixture is that the fuel has 100's of different chemical components which all ignite at different temperatures. At cold temps only a certain components of the fuel burn, call it component X. So the mixture needs to be rich so that there is enough of the component X to run properly.
reggid
Sun Oct 01, 2006 11:10 am
Brianmoooore wrote:Not in the slightest. Unmodified E30s cannot gain the slightest advantage from using any fuel with more than the minimum octane rating required to prevent detonation.
adding to that higher octane fuels often have a lower lower heating value i.e. less energy per unit of mass so you may lose a hp or so.
Martinaston
Sun Oct 01, 2006 2:28 pm
sooty, it was a bit pointless posting the measurements then :mad:
blingsta
Boost Junkie
Sun Oct 01, 2006 3:09 pm
cheers guys..
Sooty
Sun Oct 01, 2006 3:58 pm
The point my friend, was to show that there is a clearly defined measurement of clearance allowing movement between the piston & bore as opposed to the hearsay of inexperienced people.
Something you obviously failed to appreciate.
TURBODOCTOR
Mon Oct 02, 2006 8:03 pm
im new to e30's but im not so new to engine building. can anyone tell me how the hell a piston can move freely up and down a bore or liner if its made size and size? thaught not! if someting is made size n size then it is a press fit is it not?
kam-325i
Mon Oct 02, 2006 9:32 pm
No...Thats an "Interference fit" or " They fucked it up again" !!!!
Sooty
Mon Oct 02, 2006 9:34 pm
:rofl:
Globulator
Mon Oct 02, 2006 10:59 pm
blingsta wrote:i changed the piston rings about 1000 miles ago and while ive had the head off ive checked the pistons
I have been studying recently some interesting threads about running in piston rings, the key seems to be about getting some torque through the engine in the first 20 miles so you grind them in properly 8O.
http://mototuneusa.com/thanx.htm
There is also some interesting stuff about flow turbulence for tuning that I may well apply to my spare 325 head I aquired!
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
