front wheel bearing hub nut
Fraz06
Post Sat Sep 30, 2006 5:48 pm
Hey zone,
im trying to remove the front wheel bearing on a 1990 316i and was wondering what size of socket i would need to remove the hub nut?
cheers zone
fraser
Sanchez
Post Sat Sep 30, 2006 5:55 pm
32mm is wrong its 36mm
smithy318i
Post Sat Sep 30, 2006 7:09 pm
36mm socket with a thin outer wall.
don't know were you got 32mm from bud.
Sanchez
Post Sat Sep 30, 2006 7:13 pm
smithy318i wrote:36mm socket with a thin outer wall.
ive lost my bearings!!!
i know its 36mm cause ive replaced mine, but dont no why i wrote 32mm is the back 30mm or 32mm.
Sorry if i mislead you Fraz06
Fraz06
Post Sat Sep 30, 2006 7:23 pm
no probs :D
Fraz06
Post Sat Sep 30, 2006 7:44 pm
Thanx for the reply is it a 6 point 36mm socket ?
cheers zone
kam-325i
Post Sat Sep 30, 2006 8:43 pm
Any "Decent" socket should do, i bought a impact socket to do mine.
Post Sat Sep 30, 2006 8:53 pm
kam-325i wrote:Any "Decent" socket should do, i bought a impact socket to do mine.
May need to be ground down a bit around the outside.
kam-325i
Post Sat Sep 30, 2006 8:58 pm
Thats true, i did have to reduce the size of the outside wall a bit.
Post Sun Oct 01, 2006 12:45 am
and a very long breaker bar!
