do e30 325's use oil?
anton
Post Thu Sep 28, 2006 9:34 am
hi people,
as the topic says, do e30 325's use oil?
if so then why? is there anyone that had one using oil and opened the motor up? how do these motors look then, healthy inside?
cheers
Anton
Splondike
Post Thu Sep 28, 2006 9:50 am
They all leak oil :mad:, may burn it if the rings are worn I guess...
Not sure if they "use" it in mechanical sense normally, some engines do... but I did not think the M20 was one of them...
Mark.
Steviec
Post Thu Sep 28, 2006 10:49 am
Mine burns oil, but im past caring now.
<a><IMG></a>
rare
Post Thu Sep 28, 2006 11:10 am
Everyone I have seen "uses" oil. They all get through it, some at more of an alarming rate than others!! An M20 without a leak of somesort would be wrong haha. Its easier to forget these engines are really rather old. And based on even older engines!!! :mad:
mrLEE30
Post Thu Sep 28, 2006 11:23 am
all engines to a certain extent burn oil, modern ones are designed to burn oil (upto a litre per 1000km for modern coated bores)
older engines burn oil as they are generally starting to get bore or piston ring wear and valve stem wear, but it is nothing to really worry about. as long as there is no excessive white smoke while the engine is running it is not a real problem. As said you will find most of your oil will be lost due to leaks.
about a litre every now and again is ok.
as long as you have oil pressure it should be ok. (by that i mean no oil pressure light on from the dash board.)
mrlee
Fushion_Julz
Post Thu Sep 28, 2006 11:57 am
Mine doesn't use any...
between oil services I rarely have to put any oil in at all...
They shouldn't use any oil, if in good nick!
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
pnd
Post Thu Sep 28, 2006 1:56 pm
They don't use much oil at all if in good shape nor should they leak oil, most however do both as most are tired. Neither of mine seem to use any oil mind you combined mileage is 170,000 and oil is changed every 3000 if they leak any oil it is fixed regardless of expense. However many factors contribute to oil use and it is not necessarily a big problem.
MadE30mike
Post Thu Sep 28, 2006 3:27 pm
My sport doesnt use any oil atol and has no oil leaks
Only tym i put oil in it is when it gets an oil change
JoeP
Location: The Bunge, Waveney Valley, Norfolk/Suffolk border
Post Thu Sep 28, 2006 3:33 pm
MadE30mike wrote:My sport doesnt use any oil atol and has no oil leaks
Same here and she's now passed 180k miles.
Alpine White 325i touring
Saying 'No' to saloon and cabriolet wrongness :-)
csl
Post Thu Sep 28, 2006 3:43 pm
Got to say i'm really pleased with my 325 engine as-touch wood-theres no leaks and it dosn't use any oil.....all that regular serviceing and oil/filter changes must have paid off :D
FBF
Post Thu Sep 28, 2006 4:41 pm
csl wrote:Got to say i'm really pleased with my 325 engine as-touch wood-theres no leaks and it dosn't use any oil.....all that regular serviceing and oil/filter changes must have paid off :D
always been the best way to get good high miles from a car..
im so sexy justin brought me back 5 times
Post Thu Sep 28, 2006 4:59 pm
they all use oil, see that pipe on the top of your rocker cover? that goes straight to the throttle body. so all the vapours go into the inlet side of the engine. Some use more than others
see at 3k oil changes they won't use alot as your not doing alot of miles
kirils
Post Thu Sep 28, 2006 6:04 pm
i have never seen a BMW that doesn't use OIL, my old one e21 316 used 1lit on 1000km, most of that was in a leak, now my e30 320i uses 1 lit on 3500km , and that is normal too for a car with 180000km on the clock.
alan325i
Post Thu Sep 28, 2006 6:54 pm
Same here also, the only E30 bm i had to keep topping up oil was one with a fubar'ed sump
Post Thu Sep 28, 2006 7:44 pm
mine uses no oil! rubbish they are designed to use oil :?
Turbo-Brown
Boost Junkie
Post Thu Sep 28, 2006 8:16 pm
Wish mine didn't use petrol :(
Post Thu Sep 28, 2006 8:54 pm
Turbo-Brown wrote:Wish mine didn't use petrol :(
don't we all
Morat
Post Thu Sep 28, 2006 9:30 pm
Mine loves oil, about half a litre every 500miles. Valve stem seals are past it and there's the bottom half of the engine is nice and shiney! Hey ho, it won't rust. The oil level warning comes on a whisper below half way (the perfect level) on the dipstick but I really can't stand the light being on so I top it back up with about half a litre which seems to take it back to the top. Its becoming a pain in the arse now that its using more oil. Exhaust manifold studs are shot so it'll be valve stem seals and exhaust studs at the same time....
Post Thu Sep 28, 2006 9:52 pm
Wife's 250,000 mile touring doesn't appear to burn any appreciable oil. Needs about a litre between (by the lights) oil changes, but most of that leaks from the head gasket.
Doesn't use any petrol either.
e30cossie
Post Thu Sep 28, 2006 9:55 pm
If you dont burn oil you are not driving your car hard enough.
anton
Post Thu Sep 28, 2006 10:13 pm
like with my 20valve rsi 115kw toyota corolla i had,
at 8100revs that lil 1600cc motor is spinning at such a rate that a slight bit of oil creeps past.
inherant cylinder head "flaw".
i think older motors do allow some oil past the rings at high revs.
Anton
Turbo-Brown
Boost Junkie
Post Thu Sep 28, 2006 10:23 pm
Think engines pretty much have to get some oil into the cylinders, even if it's just what doesn't get carried back down the bore by the oil control ring.
Presumably at least some small percentage of what's left on the cylinder wall will burn off, and as Simon13 says there's the crank case ventilation that goes (on the standard setup) into the engine.
Similarly there'll be a tiny bit that gets past the valve stem oil seals and either finds its way into the engine, or just gets burned off the exhaust valve stems as the cylinder is emptied.
Post Thu Sep 28, 2006 10:42 pm
LPG by chance?!
Post Thu Sep 28, 2006 10:45 pm
Simon13 wrote:
LPG by chance?!
Got it in one!
Oil still clean when it comes out as well!
Turbo-Brown
Boost Junkie
Post Thu Sep 28, 2006 10:49 pm
Brianmoooore wrote:
Simon13 wrote:
LPG by chance?!
Got it in one!
Well oil be damned!
There, I said it so no one else needs to!
Fushion_Julz
Post Fri Sep 29, 2006 12:44 am
Simon13 wrote:mine uses no oil! rubbish they are designed to use oil :?
you keep telling yourself that, chap...
If you want to see one that uses almost no oil, then mine is a good example...
The engine is pretty much leak-free...OK, a VERY small amount gets burnt off, but if it uses 0.5lt between 8-10K mile oil changes then that is the limit of it!
--alpina--
Post Fri Sep 29, 2006 2:05 am
Oh for gods sake FBF what the F--K is that as your icon? is it a pig with bosan? or something alienated that got shagged and gave it some serious dose of rear end pain...?? winkeye winkeye
daaamn hope all secure rubbers were used during the session....
jimi
mrLEE30
Post Fri Sep 29, 2006 9:26 am
had a car in UK that burnt sh1t loads of oil, around about 40-50 litres a month, more if i drove further.
engine was fine though.
mrlee
Dr Firefly
E30 Zone Doctor
E30 Zone Doctor
Post Fri Sep 29, 2006 10:00 am
40-50 litres is a hell of a lot - you weren't putting it in the fuel tank were you?
blingsta
Boost Junkie
Post Fri Sep 29, 2006 10:16 am
that was a good 1 !!!!. ha ha ha
mrLEE30
Post Fri Sep 29, 2006 10:18 am
of course i was, it was a diesel :roll:
my boat uses about a litre per weekend....
mrlee
320Touring
Post Fri Sep 29, 2006 6:20 pm
mrLEE30 wrote:of course i was, it was a diesel :roll:
mrlee
ouch :D
I recall Brianmoore saying
"if you see an m20 with no oil leaks, chances are it has no oil in it..."
csl
Post Fri Sep 29, 2006 6:34 pm
Yes i know where your coming from , but theres a difference between normal usage and "useing" oil imho. However my oil level is still on the max mark,which is where it was when i bought it in june (only about 2k ago admittedly !) and the engine dosn't recieve any "grief" :!: :D
tonyppe
Post Fri Sep 29, 2006 7:22 pm
i hate that oil vapour breather.
when i first got my e30 i used to hammer it practicing going sideways round roundabouts and snaking it everywhere in the wet. the revs were always up high when doing that. i used to hate myself afterwards, but worse thing was all that oil in the induction pipe. one freezing cold january morning i used my alarm to start the car, and it started but then cut right out. the alarm started cranking it over again after a few seconds and when it did start it was chasing the idle for a while! i bought some carb cleaner stuff and washed it all out soon as. been fine ever since. :)
all cars use oil really. if they didnt, then it would mean that absolutely no oil is getting past the 3rd ring. if this was the case then the 3rd ring wouldnt be properly lubricated, therefore would have a lot of friction causing it to wear, then inturn would definatly start letting oil past... ??
if any of you rev your motor and bounce it off the limiter a few times, go and smell the exhaust. i guarantee you will smell oil
for those that earn so much money that they change their oil every 3k, and never let their swingometer read 30mpg or less 1- good on you for protecting the environment :cool: 2- your not going to notice oil loss in that short time 3- can i have an application form for your well paid job :D winkeye
StuBeeDoo
Post Fri Sep 29, 2006 7:48 pm
Mine's got a slight leak out of the camshaft oilseal. I have to put about half a litre in between changes (at 5k miles).
