as above! (with diff on car!) cheers
Tel
whats the quickest way of telling an lsd from a normal diff?
buster
by far the easiest way is do a doughnut,if it spins tight without the front end moving,lsd.also leaves 2 black lines not 1.But the safest way is to jack the whol rear end up.Spin one wheel,if the other turns in the same direction = lsd,if it goes opposite,not lsd.
telski789
cool,the cars im looking at aint running! any other way visually of checking? a stamp or anything? cheers,Tel
buster
i think if you find the tag it should have a S on it.Its a metal tag bolted through one of the cover holes.
telski789
ace,cheers!
buster
aswell as the S it has the ratio also
