Who`s swapped a roof lining?
eko
Old timer
Post Wed Sep 27, 2006 7:28 pm
Soon im going to be swapping the roof lining in my SE for the Black lining from my 318is.
Who has done this?
Any tips to make life easier?
tomson
Post Wed Sep 27, 2006 8:38 pm
Have plenty of patience when you refit the new one :D
316eyes
Post Wed Sep 27, 2006 8:53 pm
Take your time stripping the old one and note carefully how it fits; and allow plenty of time to do the job.
Nothing worse than a badly fitted, saggy h/lining! :(
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
ed325i
Post Wed Sep 27, 2006 9:26 pm
I am thinking about doing this so any info would be good. All I have been told is its not fun.
Martin347
Post Fri Sep 29, 2006 9:10 am
Its not as bad as people say. I did it with a new lining though, is yours new os second hand? You'll need some Evo-stik 528 glue, its the only stuff I could find that would stick fabric to a painted surface. You have to paint it on both surfaces then leave to dry for 15mins then put them together. It worked well for me.
eko
Old timer
Post Fri Sep 29, 2006 9:11 am
Martin347 wrote:Its not as bad as people say. I did it with a new lining though, is yours new os second hand? You'll need some Evo-stik 528 glue, its the only stuff I could find that would stick fabric to a painted surface. You have to paint it on both surfaces then leave to dry for 15mins then put them together. It worked well for me.
Where do i need the evo stick for?
Round the door frames presumably?
Martin347
Post Fri Sep 29, 2006 10:04 am
Well, I used it round all the windows/door lips (where the rubbers go onto). I had all the windows and rubbers out at the time. Are you going to take the windows etc out?
Demlotcrew
Post Fri Sep 29, 2006 10:11 am
The sunroof/rear quarters/rear window need to come out. (ON a 325i SE)
Andrew
