Help - can't make my car track straight
klu99apm
I bought my 325 touring nearly a year ago and its always pulled to the left when driving. It pulls quite hard â┚¬Ã¢â‚¬Å“ you couldnâ┚¬Ã¢”ž¢t let go of the steering wheel on the motorway unless you want to do some fast lane changing! I thought it would be quite a simple thing to fix but I might have been wrong!
So far Iâ┚¬Ã¢”ž¢ve changed both control arms and the tie rods (as the joints on these were picked up on the last MOT as being worn). Its had its tracking checked twice but no change.
What is the next thing to check? Could something else be bent underneath or the steering rack be a suspect? Any help or suggestions would be much appreciated!!
Don't assume it's the front suspension for a start.
Check the steering wheel turns exactly the same number of turns in each direction from straight ahead.
Tie a piece of string all the way around the car, half way up the wheels. Are the rear wheels both pointing straight ahead? What about the fronts?
Globulator
You might also want to check the left-hand wheels after a drive - for being too hot, it is possible you have a brake binding.
Apart from that you may want to check the 'camber' - the vertical angle of the wheels - both sides should be equal.
If one camber is greater/less than the other side, the wheel castor (tendency of a wheel to track straight set by the angle of the strut pivot) will pull the car sideways too.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
klu99apm
I think you're onto something! The steering is just over two complete turns to the right to full lock but just under two complete turns to full lock to the left.Check the steering wheel turns exactly the same number of turns in each direction from straight ahead.
What exactly does this mean and how can it be fixed
Check that equal lengths of thread on the tracktod ends is showing at each side.
Have you checked front and rear tracking with string yet?
beardymat
- Location: sheffield, city of steel, and rust apparently
dont forget to make sure the front tyres have equal tread left on them and pressures too,if one is worn and the other not that will make it pull too. you wouldnt think it but it does
blingsta
- Boost Junkie
i had same problem on my old e30 cab... changed loadsa bits n bobs... still the same..it came down to being the whole strut that was the problem. i changed the whole thing complete and it was perfect... 2 days later car got written off!!!
blingsta
- Boost Junkie
Ahh, one more thing to check... get a piece of string, and measure from the centre of the strut top mounts nut, to the centre of the nut on the drivers side windscreen wiper !! they should both be exactly the same...
klu99apm
Thanks for the extra replies. When I replied yesterday I should have said its not the brakes binding as I changed the pads and discs recently and they were equally worn.
I'll report back in a bit
I haven't done this yet, but will it show anything different to the 4 wheel tracking I had done last week?Have you checked front and rear tracking with string yet?
I'll check this laterCheck that equal lengths of thread on the tracktod ends is showing at each side
The tyres are equally worn and equal pressure.dont forget to make sure the front tyres have equal tread left on them and pressures too
I'll try this, this morningget a piece of string, and measure from the centre of the strut top mounts nut, to the centre of the nut on the drivers side windscreen wiper
I'll try not to do this!!2 days later car got written off!!!
klu99apm
I've checked the list of things above.
There is slightly more thread showing on the track rod end on the offside. (about 2mm)
The distance from strut top mounts to the windscreen wiper nut is the same on either side.
Any ideas please ?
Any ideas please ?
blingsta
- Boost Junkie
i would suggest changing the whole strut...
klu99apm
Which one? the offside?i would suggest changing the whole strut...
Would this show up on the tracking as caster or camber? (I'm a bit out of my depth with this!) I'll try and post up the sheet of info I got when I had it tracked last weekend.
Did you just have it checked, or adjusted as well? Was it like this before?
Can't see what changing the strut is likely to achieve without proving if it's bent first.
klu99apm
Here's a copy of the data I got when I had the car's tracking checked last weekend:
http://img434.imageshack.us/img434/4709/dscf0016tr8.jpg
Does this shed any further light onto the problem?
Andrew
Andrew
klu99apm
Since last posting I've swopped over the front tyres.
I know that they'll be rotating the wrong way but it was just an experiment.
Now instead of tracking to the left it now goes to the right.
I guess this means the tyres are to blame? They don't look worn significantly and aren't feathered badly but i guess they're the cause?? They're only some budget tyres that were on the car when i got it (They're "Matador's" made in czech republic or something) I think its time to change them!
