mystery noise from clutch
pilotskillse30
Post Tue Sep 26, 2006 12:14 am
Hey guys, wondering if anyone might help me out here, I have a 1993 325i (e30)convertible and I just replaced the slave cylinder...2 days later I get this whine when I press the clutch down , it still shifts but ,that dam noise...oh and I get a bit of pedal vibration as well, goes away when I press the clutch down.
HELP!!!.......will post pics soon
DRIFTBOY
Post Tue Sep 26, 2006 12:24 am
Doesn't sound anything to do with the slave cylinder to me.
Normally if the clutch release bearing (or thrust bearing as it's also called) is worn it makes a noise and sometimes even a vibration which goes away when you push the clutch pedal down. Sometimes even new ones do it a bit so it's likely to be nothing to worry about, depends just how bad it is!
