ops it will not start OBC ????
exup
Boost Junkie
Post Mon Sep 25, 2006 6:39 pm
Hi
I ve justed finished fitting my 2.7 into a 1990 e door se model ,
but it will not start , it cranks over fine , could it be the OBC requiring a code ???
ops how do i fine it out or by pass it as the battery been off it for 6 weeks assume OBE may need a default code to start it now
?? HELP :-x
Post Mon Sep 25, 2006 7:37 pm
OBC CODE defaults to off when the battery is disconnected. That's why it's just about useless as a security device.
First check is for 12V+ at the + terminal of the coil when the ignition is on and you try to start it. (connect a small (5W) 12V lamp between the coil + terminal and battery negative).
exup
Boost Junkie
Post Mon Sep 25, 2006 7:48 pm
Will try the coil supply ,
cheers as always ,
thanks Brian
