timing belt wont go on?
blingsta
Boost Junkie
Post Sat Sep 23, 2006 6:15 pm
Hey guys!, having got myself a 3mm decompression plate to lower my c/r, ive been trying to put car back together, but my timing belt wont fit???? ive undone the tensioner all the way, but still no go... any advice please?
bottlecapE30
Post Sun Sep 24, 2006 4:49 am
you might beable to gain a little slack if you losen the water pump and the tensor might push over a little more.
just a guess you might want to try.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
blingsta
Boost Junkie
Post Mon Sep 25, 2006 10:24 pm
Today i tried again and this time i took the spring off the tensioner so it went ALL the way back.. still no joy... does anyone know if all timing belts from any car will fit, im thinking of trying a longer belt, can anyone advise pls??
Andy335Touring
Post Mon Sep 25, 2006 11:55 pm
Trouble with a longer belt is it might throw your valve timing off a touth or two ???
blingsta
Boost Junkie
Post Tue Sep 26, 2006 12:00 am
i think i can afford 1 tooth off as m/s will compensate for it... but you would have thought that 3mm is nothing and shouldnt affect the belts length as thats what the tensioner is there for, surely the tensioner slackens more than 3mm??????
tonyppe
Post Tue Sep 26, 2006 12:02 am
is it definatly for your size engine?
im thinking if u got a 2.5 engine with a 2.0 belt that the 2.5 block is taller therfore needs a longer belt and u might have a 2.0 litre belt?
Andy335Touring
Post Tue Sep 26, 2006 12:03 am
Sorry, i'm not to clued up on the M20 set up, my M30 is chain driven so no nasty belts to change or snap ! :)
tonyppe
Post Tue Sep 26, 2006 12:11 am
chains are the way backward to go forward :p lol
blingsta
Boost Junkie
Post Tue Sep 26, 2006 12:12 am
my blocks a b27 and heads a 325i... im sure its same belt!
tonyppe
Post Tue Sep 26, 2006 12:20 am
yer must be cos i read that the blocks were the same but the crank was different.
bottlecapE30
Post Tue Sep 26, 2006 2:08 am
i just found ot there are two types of belts for the m20 one has 128 teeth and the other is 129 teeth so if you don't have 129 teeth then get that belt. other wise i would think that the belt would be to tight if it won't go on with the tensor. Maybe a call to bmp design is in order as they sell a thicker gasket that they use on many FI m20.
EThreezero
Post Tue Sep 26, 2006 2:19 am
I think its actually 127 and 128 teeth for the 325i dude, ive not long bought one for mine.
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
bottlecapE30
Post Tue Sep 26, 2006 2:23 am
you might be right i might have just read that wrong
blingsta
Boost Junkie
Post Tue Sep 26, 2006 12:28 pm
yeah thanx guys.... i take it any got parts store would sell them :?:
12345kevin
Post Tue Sep 26, 2006 1:35 pm
Just an observation :) If youv'e raised the head by 3mm wouldn't the belt need to be 6mm longer ?
blingsta
Boost Junkie
Post Tue Sep 26, 2006 2:03 pm
i see where your coming from but dont forget the tensioner takes up some slack! i would have thought it takes at least 6mm slack anyway?
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Sep 26, 2006 2:04 pm
Give ECP a bell tell them what your after fella, or try GSF
Templ8e30
Post Wed Sep 27, 2006 10:16 am
12345kevin wrote:Just an observation :) If youv'e raised the head by 3mm wouldn't the belt need to be 6mm longer ?
Quite right matey, you may need a vernier pulley to correct the cam timing too :?
Cheers,
Iain T
2007 Mazda 6 2.0 estate
tonyppe
Post Wed Sep 27, 2006 11:07 am
blingsta wrote:Hey guys!, having got myself a 3mm decompression plate to lower my c/r, ive been trying to put car back together, but my timing belt wont fit???? ive undone the tensioner all the way, but still no go... any advice please?
lol i missed this
but if there are more teeth in the belt wont there need to have a bigger pulley??
blingsta
Boost Junkie
Post Thu Sep 28, 2006 9:20 am
Cheers for all the comments guys.... ive finally got the belt to go on (half a tooth advanced), but hey, i need the car up and running, and will consider a vernier pulley soon, but for now i'll let my m/s sort it out
Templ8e30
Post Thu Sep 28, 2006 10:26 am
lol i missed this
The belt length could be 2000 teeth in length but as long as the crank and cam pulleys are the correct size it'd stay in time.
Cheers,
Iain T
tonyppe
Post Thu Sep 28, 2006 11:58 am
cheers :)
you know what this means! :) more bottom end power! Grunt grunt lol you will also notice more induction noise :D
