throttle housing heater thingy
Guest
Post Sat Jan 15, 2005 7:50 am
Ive had to strip down the inlet side of my 318is as the fuel rail pipes were leaking (cold weather did it ?)
ive since found that all of the breather hoses are split to some extent so im having to replace them all (seems to be 10 or so hoses ?) Theres an awful lot of pipework under there for some reason,
i need to get it on the road as soon as possible and cant really wait for the parts, so i was proposing on bypassing all of the water plumbing (im having to replace that too)
http://www.realoem.com/bmw/showparts.do ... g=11&fg=35
basically joining points 20 and 12, i was wondering what that heater plate is for in the throttle body - i thought the general idea was to get colder denser air into the engine ?
so is it ok to bypass this ?
Geeman
Post Sat Jan 15, 2005 8:53 am
Yeah, I did exactly this on my track car.
Took the sandwhich plate out completely, but had to re-route the air pipe that was in there though up into the blanking plug on the air intake bellows... it's not that hard...
You must make sure that all the air pipes have no splits in them, otherwise the car won't run well... very important!
Giles.
Guest
Post Sat Jan 15, 2005 9:19 am
so itll make no difference to daily driving ?
yeah they are all split pretty bad, ill have the hoses on order next week - going to replace them temp with some hose for now.
Geeman
Post Sat Jan 15, 2005 9:25 am
To be honest, I would have thought it would make no noticeable difference. I haven't had the car out since I did it, but it idled okay and revved freely, so no problem there.
Then again, it's only used on the track, so no cold starts or anything...!
Guest
Post Sat Jan 15, 2005 12:04 pm
heh im having trouble actually joining points 20 and 12 - different size bore - any ideas ?
Geeman
Post Sat Jan 15, 2005 12:12 pm
Yeah, join 19 ( the one on part 25 ) to 12 using hose 11... You'll have to trim hose 11 to fit straight to 25...
Or you could even use hose 16 to fit straight between 12 and 25...
Either way, you'll need to do a bit of hose trimming...
You need to keep parts 17 and 25 anyway, as they're used for the air pipes... so you'll keep part 26 in the loop.
HTH
Giles.
Guest
Post Sat Jan 15, 2005 3:55 pm
water hoses look a little iffy to reuse, just a thought, but do i really need a loop in there ? - im wondering if i can just blank each hole off (that is 20 and 12) - other than that ive no clue what to do!
Geeman
Post Sat Jan 15, 2005 6:35 pm
Erm, I wouldn't block them off... just in case they're needed for the flow of water. If you can find out where the flow goes from 12 into the cylinder head, than that's fine, but I'd be cautious... the iS head is very fragile...
Karan
Post Sat Jan 15, 2005 8:26 pm
throw it in the bin--ive done this on 2 iS engines no probs at all
dunno why they did it although im sure someONE can tell us LOL
BIN IT
Karan
Geeman
Post Sun Jan 16, 2005 10:42 am
Que: Andy... :lol:
Guest
Post Sun Jan 16, 2005 6:13 pm
well its all back together - i did a bit of a macguyver on the pipework - but theres a lot less joins now - the breather hose arrangement is a lot less complicated for instance (eg part 17 and 25 arent on the car at all!)
heres my hose i made up
car seems to be running a lot better now i got rid of all the old split hoses
Demlotcrew
Post Sun Jan 16, 2005 8:14 pm
Geeman wrote:Que: Andy... :lol:
To stop the Throttle body freezing up during really cold weather.
