right my fuel gauge has started to play up, it flickers from empty to full and sometimes just falls to empty etc when driving
when i turn my ignition on it reads full, --when there isnt a full tank of fuel
the reserve light works as does everything else on my clocks
i have recently replaced to fuel pump for a second hand one
i thought it was the sender unit which comes with the fuel pump, i have changed 3 of these but no luck,
i have also changed the Si board and used my original dials, no luck
i have used my orignal Si board and just replaced the fuel gauge but still no luck, also tightened the nut on the back of the gauge
the closest i have got to finding the source of problem is this---
on the passenger side of my car under the rear seat, there is a round plastic cover, when removed it reveals something which looks like the fuel pump, but i know that the fuel pump is on the drivers side
maybe this is the return unit or something, anyway
if i unplug this and turn my ignition on, the fuel needle doesnt move at all, and my reserve light still works ( fuel is on reserve)
is this faulty then or is it something else
thanks in advance for any advice??
fuel gauge going mad??
sajid1
The sthing you have found is a level sensor for the left side of the tank. This is connected in series with the one in the fuel pump.
As a check, pull the plug of this, and arrange a short circuit between the two pins of the connector.
If this gives consistant, although excessive readings on the gauge, then this sensor is faulty.
sajid1
ok thanks, will try this and get back to you
