power steering very noisy ,high pitch rubbing squealing
robbo80
Post Mon Sep 18, 2006 7:49 pm
Very noisy most of the time and heavy 75% of the time , Can someone tell me how differcult this would be to fix my self. and how much it would cost at a garage. thank you
gilb
Post Mon Sep 18, 2006 7:57 pm
iv got the same problem does your fluid go down after a day or so think most ov it will need replaceing
robbo80
Post Mon Sep 18, 2006 8:03 pm
no i have replaced the fluid once , but not because it was leeking ,just in hope it would fix the problem . didn work
Chris-W
Post Mon Sep 18, 2006 8:20 pm
Have you checked the tension of the belt?
robbo80
Post Mon Sep 18, 2006 8:22 pm
its not really tight and its not loose , what ideally should it be like
gareth
Post Mon Sep 18, 2006 9:45 pm
it should move about 1/2 an inch midway with relatively little effort
it may be your pas pump. does it sound like a fanbelt type noise or more of a grinding noise?
robbo80
Post Tue Sep 19, 2006 12:08 am
its high pitch squeal , the thing is it doesent sound like its coming from the front of the engine it sounds like its coming from behind the steering wheel a bit like plastic when it rubs tightly together.
