................................cheers phil
fitted my obc ......problem......
darlofil
hi yall i fitted my obc yesterday all nice n easy no probs all working great ..... went for a drive came home turned the car off and it didnt ......it just stayed running had to stall it to get it to stop .no dash lights on after i stalled it ..and started up again as normal (with a bong from the obc lol) but would turn off again????????? any ideas folks???????
E30Mark
Had this on mine, seem to remember disconnecting the in-line green connector on the OBC loom behind the glove-box, sorry but i can't quite remember which bit i unplugged!
Start the car then return the key to the off position, then pull out the connections on the OBC loom and see which one causes the car to stall, hopefully the OBC will remain working!
PM for details
PM for details
The immobiliser wires (looped into green ignition wire above glovebox), go to a relay in a black box above the engine ECU. This box also contains a relay for the CODE function alarm, which has a remanent 12V+ feed, so, somehow, I expect these two are connected together.
darlofil
cheers m8 that seems to have done the job ...........
