fuelpump relay
koenvandermolen
Post Fri Sep 15, 2006 6:00 pm
Guys,
Where can I find the fuelpumprelay in the E30 5/1991 series. Is it fitted somewhere under the steeringwheel?
thnx!
Post Fri Sep 15, 2006 7:17 pm
Question doesn't make sense! E30 is a 3 series. 1991 3 series is an E36, unless it's a touring or cab. 1991 5 series is an E34 and the fuel pump relay position on any of them depends on the engine size.
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Fri Sep 15, 2006 7:48 pm
I assume he means e30 registered in May 1991?
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
Chris-W
Post Fri Sep 15, 2006 7:54 pm
Well, it's either going to be under a small black plastic cover near the Airbox, or under the long lateral black plastic cover on the bulkhead.
I'm hoping we can assume it's an E30 based on the forum the question has been posted on?
koenvandermolen
Post Sat Sep 16, 2006 7:36 pm
oops,
I meant indeed may 1991. I'll check it out
pnd
Post Sat Sep 16, 2006 7:44 pm
White relay under the black plastic cover just back from the airbox on my 1990 sport.
gazza
Post Sat Sep 16, 2006 9:34 pm
if its a 318 then under the black trim strip along the bulkhead ...325 n/s wing near the strut mount inder a small black plastic cover
Post Sat Sep 16, 2006 10:04 pm
It's a 1991 E30 cab. He's got another thread on the go which i found just after I posted the above, and answered his question on that thread.
koenvandermolen
Post Wed Sep 20, 2006 11:22 am
The problem was the fuelpumprelay. I replaced it with a new one. I was wondering by the way, if there is a difference between the fuelpump relay and the orange ones in the fusebox. Cause the seem to have the same connectionpointnumbers...
Post Wed Sep 20, 2006 7:38 pm
Same relay AFAIK. Nothing special about it - just a simple single pole normally open 12 volt relay.
Chris-W
Post Wed Sep 20, 2006 7:42 pm
Yep - same, or certainly function the same, having used them both for the same purpose in the past.
