central locking full closer sunroof etc
ukdirtyboy
Post Fri Sep 15, 2006 12:14 am
hi all anyone know if their is one wire that will give me full closer when wired to the alarm ie windows c/locking sunroof etc and has anyone got a clue how to wire remote start
one wire to starter ?
one to acc ?
one to tacho ?
just guessing
Jos
Post Fri Sep 15, 2006 8:27 am
e30s don't have total closure available for the simple fact that you have to hold the buttons for the sunroof and windows down to get them to work. The only cars you can do total closure on are ones with a 'latch' circuit so 1 press takes the window to the close position. I think a while back someone posted a module kit that would allow closure, then you can use the switched outputs on the alarm to operate it.
Sunroof is harder as closure can be either button depending on the position of the sunroof (tilt or slide)
Remote start you would need to take the ignition wires as the source then map them through the remote start unit. Shouldn't need the tach cable for it, just the 2 wires from the key barrel for ignition and crank.
<Waits for Brianmoore>
'94 e36 tree climber
