if im............
TW166Y
Post Sun Sep 10, 2006 2:46 pm
doing this m50 conversion will my 4-pot e30 be ok to hold the extra weight up font? i think ill be buying a suspension setup anyway, undecided what do go for, but i just want to get the correct advice before i start spending. thanks
Saying goodbye to 4-pot wrongness
maxfield
Post Sun Sep 10, 2006 2:47 pm
I wouldn't f thought there would be a problem as alot of people have put a 2.5 in a 1.8 shell without man susp mods
ad318i
pretty sure you need a new suspension setup as the new engine heavier..
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
Springs could do with swapping for 6 pot ones. The M50 is a lot heavier than an M40.
TW166Y
Post Sun Sep 10, 2006 4:20 pm
Brianmoooore wrote:Springs could do with swapping for 6 pot ones. The M50 is a lot heavier than an M40.
see this is what i thought brian... is this going to be a case of buying a complete suspension package for a 4-pot and swapping the front 4-pot "new springs" for a pair of 6-pot springs then?
or if its all new anyway should it hold up the weight etc..... ?
dazleeds
old skool raver
old skool raver
Post Sun Sep 10, 2006 4:29 pm
deffo do the suspension mate
not worth taking chances in that area
www.oldskoolfantasy.co.uk
fuzzy
He who sleeps with "Gingers"
Post Sun Sep 10, 2006 4:41 pm
id wait until the engines in to see how high the front ends sitting before you order springs but id definately fit new uprated shocks as well.thats what i did with mine although it was an odd experience driving with spax -40 springs and shocks on the back and standard spings with knackered shocks on the front until the new ones came winkeye
TW166Y
Post Sun Sep 10, 2006 5:11 pm
thanks all, so its a case of suck it and see yeh? :D
Post Sun Sep 10, 2006 5:36 pm
I used 325 suspenson and brakes all round on mine, even ABS :wink:
You can pick up some front stuts cheap enough, its worth doing as they use the larger diameter damper inserts 8)
Chris-W
Post Sun Sep 10, 2006 6:15 pm
Twiggy, if you want a set of front struts I have some on the 325 I'm breaking.
You could come over and swap them in.
Cheers,
Chris
Bob_S
Post Sun Sep 10, 2006 7:02 pm
steve tigger will know wont he?
I'd take up chris on his offer though you will need to uprate atleast the springs
Bollocks to this 24v scrap!
