Right then, looks like someone may have had a go with a screwdriver and the boot lock is now completely buggered!! You can still put the key in the barrel and when turned it works the central locking still. However, pressing the button in now does nothing at all!! If i press it a bit further it will push back inside the bootlid now.
So the problem is, i can't get in the boot!!
Anyone know how to open the boot without causing any damage??
Feel free to pm me if it's info that would make it easy for someone reading this to break in!
Cheers,
Rob.
Smithy318i - Touring boot lock buggered!! Help!!
miniblob
327 Touring with bass!!!
Chris-W
smithy318i
Pm sent.
miniblob
Nice one Smithy - i'll might give that a try!!
oze30
Smithy, could I get a copy of that aswell? I need it for Justin! ;)
whipsey
i could do with that as well mine's not working on the key
miniblob
Smithy - noooooooooooo!!!!!!smithy318i wrote:Pm sent.
Was just gonna print out that pm and it's dissapeared from my inbox!!!!
Could you send it again please???
Dunno if i deleted it by mistake, or if they time out or something!?!?!
stuartgallafant
If you can get the plastic inner cover off the tailgate, it's obvious how to release the catch (by unscrewing it).
miniblob
Coolio, spoke to Tee anyway and he knows about changing the lock inners so i can keep the same key!!!!!
You don't have to use my methods Stu!!!!!
And when you do get in, you can have fun fitting all the bits that are in there!!!!!
stuartgallafant
