I am looking for some BBS split rims for one of my 325i Tourings, but information I am getting is a little confusing regarding the correct offset.
Rochford Tyres say it should be 15-25 but a highly reputable source within the E30 fraternity quotes 15-18. At between £500-£1000 for a set of rims I need to be sure this that I have got it right.
The specs offered are: Rim Width: 7J, Tyre Width: 195, Rim Diameter: 15 in, Aspect Ratio: 50, Offset: 25, Number of Studs: 4, BBS part No: RS001
Any helpful comments will be much appreciated
CORRECT OFFSET?
NigelA
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
jmc330i
The standard 15x7 BBS wheels (the ones on the tourings in your sig pic) have an offset of 24, so you should be ok with 25.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
NigelA
Many thanks, James, for your quick reply and helpful comments. Should look good on the blue one then.
Regards
Nigel
Regards
Nigel
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
chu346
The tyre size is incorrect though.
Standard tyres are 205/55/15.
Gwynleym10
While we are on the subject with wheels with an offset of 28 fit?
Will they stick out further or less?
chu346
Stick out less....the lower the number the further out they sit.
jmc330i
Depending on the width of the wheel, you may need spacers with an offset of 28. 6x14s are ET30, but only 6" wide, so 7" or 7.5" ET28 wheels may fit, but it might be close.
James
'91 325i Sport
'91 325i Sport
jmc330i
Just out of interest, who said 15-18?NigelA wrote:Rochford Tyres say it should be 15-25 but a highly reputable source within the E30 fraternity quotes 15-18.
James
'91 325i Sport
'91 325i Sport
NigelA
Yes, I have 205/55/15's on the current BBS rims so presumably those tyres would not fit onto the splits I am looking atchu346 wrote:The tyre size is incorrect though.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
NigelA
Don't want to put names into the public domain, as I am sure you will understand. Call me on 07974 8/01747jmc330i wrote:Just out of interest, who said 15-18?NigelA wrote:Rochford Tyres say it should be 15-25 but a highly reputable source within the E30 fraternity quotes 15-18.
Regards
Nigel
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
NigelA
Last message. Number should have been: 07974 801747
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
chu346
I think i must be missing something, why wont the current tyres go on the BBS splits.
The wheels are both 15"x7"?
