Pedal box removal?
eko
Old timer
Mon Aug 28, 2006 8:22 pm
Bit of advice please guys.
Need to remove the peddle box from my breaker for an auto conversion.
Started taking the dash out earlier,almost done.
Question is,how do the pedals come out?
I mean,is it the complete assembly that i have to change or can i simply remove the clutch and brake pedals and refit these in the auto?
Any help appreciated :D
stevetigger
Mon Aug 28, 2006 8:38 pm
eko
Old timer
Mon Aug 28, 2006 8:44 pm
Nice one Steve.
Looking at that,it looks like i may have to change the full assembly in one.
Is this possible without stripping the whole thing into bits?
Can anyone who has done this confirm?
smithy318i
Mon Aug 28, 2006 9:05 pm
it comes out in one big chunk. iirc there are about 6 nuts holding it to the bodywork. The brake rod also needs to be lossened.
eko
Old timer
Mon Aug 28, 2006 9:06 pm
smithy318i wrote:it comes out in one big chunk. iirc there are about 6 nuts holding it to the bodywork. The brake rod also needs to be lossened.
Smithy your a star-thats what i needed to hear!
Accelerator linkage part of main assembly or seperate?
smithy318i
Mon Aug 28, 2006 9:12 pm
linkage is part of assy, except the pedal itself.
eko
Old timer
Mon Aug 28, 2006 9:18 pm
Nice one Smithy,now i know what to expect/do,thanks mate :wink:
stevetigger
Mon Aug 28, 2006 9:35 pm
Thought it came out in one, but didn't want to say in case I was wrong again!
eko
Old timer
Mon Aug 28, 2006 9:38 pm
stevetigger wrote:Thought it came out in one, but didn't want to say in case I was wrong again!
but Steve your never wrong...........
stevetigger
Mon Aug 28, 2006 9:42 pm
Only when I am right! :D
Quaser
Tue Aug 29, 2006 9:13 am
10 bolts, and a circlip for the brake rod.
Also needs to remove slave cylinder. Easy Peasy
eko
Old timer
Fri Sep 01, 2006 6:30 pm
Right guys i got the pedal box out today but need to check a couple of things with someone in the know!
When removing the pedal box i couldnt see the clip holding the linkage bar to it,so i just `forced`it out from behind the heater box 8O
Looking at it now i can see the pin and clip but its in upside down?meaning the isnt enought room to withdraw it :mad:
So can i release the lock nut and unscrew the rod thus leaving it in place?
Also i removed the full dash on the breaker to get to the pedal box,will this be nessarsary on the new car or can i work around it?
Quaser
Fri Sep 01, 2006 10:50 pm
as long as you screw the rod in exactly the correct position, it should be ok.
the dash can stay on the car
eko
Old timer
Fri Sep 01, 2006 10:52 pm
Quaser wrote:as long as you screw the rod in exactly the correct position, it should be ok.
Youve made my day,thanks mate :wink:
