alternator belt
gilb
Post Mon Aug 28, 2006 6:06 pm
any1 no how 2 adjust these as mines doing my head in wont stop squealing iv replaced the belt once before but seems like it needs doing again and i fink its causeing my car 2 overheat as the fan wont b turning quick enough
stonesie
Post Mon Aug 28, 2006 7:00 pm
same as when you fitted it mate :wink:
slacken the alternator, tension it then re tighten the bolts, i would set it so theres about half an inch each way of play in the belt on its longest run between pullys
edit just had a look on mine and to tension it theres a big (19mm??) nut with teeth on the back which go in another set of teeth on the bracket, this makes it so easy, no leavering with bars ect winkeye
gilb
Post Mon Aug 28, 2006 7:31 pm
ha so easy my arse there is a nut with teeth which should tention it but it dont seem 2 work just comes loose again
stonesie
Post Mon Aug 28, 2006 9:00 pm
maby bars are needed on yours afterall....... VW-audi's ect use the same system if the nut has gone on yours maby a replacement would help :wink:
i found they fit nicely in the pocket when the teeth went on mine on the old VW 8O
