Are the electric window motors in a facelift a staight swap into a pre facelift?
I know ill need to change the glass but need to know if wiring connections are the same?
Change the door loom,that simple?
E/window motors interchangable?
smithy318i
glass and mechanism are different. however they work the same electicly. No need to replace the loom.
eko
- Old timer
Just needed it confirming,thanks Smithy
smithy318i
you do know that the mounting points on the inside of the door are different ! So you cant put the wrong mech inside the door (it just wont fit)
eko
- Old timer
?smithy318i wrote:you do know that the mounting points on the inside of the door are different ! So you cant put the wrong mech inside the door (it just wont fit)
You mean the factory drilled mounting holes are different?
smithy318i
as far as i am aware, the doors have different mounting points for the e/w between pre and post facelift.
eko
- Old timer
Bollox,think ill whip the panels off both cars tomorrow and have a look!
Was planning on swapping the Black glass to my project car but well soon see.
Nice one S
mithy
Nice one S
