HOW DO I PUT OUT MY INSPECTION LIGHT????
DORAS
Post Sun Aug 27, 2006 5:16 pm
JUST DOING A BIT OF WORK ON THE MOTOR AND LOST THE BIT OF PAPER TELLING ME HOW TO PUT OUT THE INSPECTION LIGHT! I HAD A FEELING IT WAS EARTH OUT NO 7 PIN IS THAT CORRECT???
THANKS RICH
Geoff
Post Sun Aug 27, 2006 5:31 pm
Hi, why dont you buy a resetting tool from euro car parts for about £15 max. Then you dont need to "short" anything out. Then you can use it for oil services and inspection services. Great bit of kit, and takes 15 seconds to use.
DORAS
Post Sun Aug 27, 2006 5:34 pm
Thanks for the reply but you dont need to spend 15 quid when a bit of wire will do! just need to know which pin.
thanks rich
Geoff
Post Sun Aug 27, 2006 5:43 pm
Yeah but will using that bit of wire put out the oil light as well then reset all the green lights?
dazleeds
old skool raver
old skool raver
Post Sun Aug 27, 2006 5:49 pm
DORAS wrote:JUST DOING A BIT OF WORK ON THE MOTOR AND LOST THE BIT OF PAPER TELLING ME HOW TO PUT OUT THE INSPECTION LIGHT! I HAD A FEELING IT WAS EARTH OUT NO 7 PIN IS THAT CORRECT???
THANKS RICH
here ya go mate
http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=02
www.oldskoolfantasy.co.uk
Post Sun Aug 27, 2006 6:07 pm
exellent !! bit of wire worked great for me it reset everthing :cool:
DORAS
Post Sun Aug 27, 2006 6:23 pm
thanks dude, pin seven for about 10 seconds did it!!
and yes it does reset the greens aswell.
