fitting M-tec 2 kit to cab
glenbat
Post Sat Aug 26, 2006 8:52 pm
thinking about getting a 2nd hand m-tech 2 kit for the cab and fitting it, how hard is it?
Guessing the front and rear bumpers will just be bolted on, how about the skirts?
am i right in thinking they are 3 piece items?
many thanks in advance
E30_Aza
Post Sun Aug 27, 2006 12:55 am
i just fitted my front valance on today after it was sprayed, it aint too bad. although i did do some mods to it to get it to fit stronger. just get the full fitting kit and you should have no problem. may have to do a bit of drilling but go for it if you want it. will make a differents on the look of your cab.
the skirts have 4 pieces each side. bottom sill and 3 pods on the side
mrLEE30
Post Sun Aug 27, 2006 5:52 am
yep bumpers just bolt on, some drilling of your lower valance and just in front of your front wheels requireed to fit the clips but not to hard. the side pods are a different story, only cab side pods fit over the sill as they are bigger on a cab, if your kit is from a tin top you need to modify it a bit.
didnt bother with the side pods myself (not keen on the look and they are rust hiders) only put front and rear bumper/valance i am happy with look.
mrlee
