Checked the obvious like had she reduced the intesity down to 0, but no the headlight pull switch rotates fine with no differance.
Have checked fuses 10, 12 and 23 all fine, and other items run from them such as check control module and reversing lights all function ok.
Window switches (which are always on still work). What ever is the cause effects everything (ie dash panel lights, full trip computer illumination and m-tech illuminated gear knob).
The dials still function ok, the trip computer still lights the display when lights are off, but when you switch them on and the additional lighting on the trip computer kicks in and it blacks out completly (ie buttons and display).
I'm assuming it must be a fault with the rotating part of the headlamp pull switch.
Any suggestions guys?
