tech 2 front valance
E30_Aza
hey guys,
i got my mate stuartgallafant to get me the fitting kit for the tech 2 front valance. fook me there are so many bits and i aint got the foggiest what to do with it all. bare in mind that when i took the front off to get repaired and sprayed it was held on with cable ties etc..... so i aint seen these fittings before. theres a rubber stipe in there and all sorts!!!!
be well greatful if anyone could help me out with this as hopefully i can fit it later tonight.
any help what so ever will help me on my way
cheers, aza
cheers, aza
Cabrio
most of the clips and studs that match will match up with the holes on the spoiler..if your car was originally supplied with mt2 it should have the holes already if not you need to carefully mark and drill the holes on the correct place on the front valance and then go from there...others will match the clips holes on the bottom of your valance thats the first step so you know it fits right and you can still fit the bumper etc
bmwe30mtech
The rubber bits push into the back of the valance to surround the foglights, and the front middle vent cut outs.
The small plastic clips push up from the bottom of the valance into the bass of the car valance.
The white plastic clips locate along the top of the mtech valance and to attatch them to the car you will need to remove the upper bumper.
The two metal 'u' shaped bits go either side of the valance, and are bolted from the inside of the front car valance. You will need to turn the front wheels to reach them.
HTH
Paul
HTH
Paul
325sportcab
cliffybabe
- Powered by Nelly
Az u tart just put it on already stop looking at it and fit it already, Isnt that what u said to me when i was doing my tec1 kit
E30_Aza
cheers fellas, its lookin a bit clearer now. but now i realise that i didnt need most of this fitting kit. just needed the black push in clips and the rubber seal. dont under stand the rubber seal sill though!! on the diagram is that it above the valance????
cliffybabe
- Powered by Nelly
U have fitted yet OMGE30_Aza wrote:cheers fellas, its lookin a bit clearer now. but now i realise that i didnt need most of this fitting kit. just needed the black push in clips and the rubber seal. dont under stand the rubber seal sill though!! on the diagram is that it above the valance????
E30_Aza
how many times do you wanna say ALREADY!!!!! tech 1 kit was more simple. you should see this bag of bits. i also got a long grey sticker thing!!! what the fuck is that??????
cliffybabe
- Powered by Nelly
luv u really Az if i was at home id come round and laugh i mean helpE30_Aza wrote:how many times do you wanna say ALREADY!!!!! tech 1 kit was more simple. you should see this bag of bits. i also got a long grey sticker thing!!! what the fuck is that??????
But im not
on a serious note have u looked on the etk at part descpitons???
E30_Aza
cliffy, DO SOME FUCKIN WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
cliffybabe
- Powered by Nelly
try this link mate the bit ur talking about is the foil is that right??
http://www.realoem.com/bmw/showparts.do ... g=51&fg=15
325sportcab
The rubber seals just push into the grooves on the back of the the valance, where the air intakes are for the oil cooler. If your getting confused with the long strip above the valance that is just a drilling jig to make you drill the holes in the right place for the black plastic clips that hold the top edge on. the rubber seals are on the diagram above the drilling jig
E30_Aza
cheers fellas. big thanks.
cliffybabe
- Powered by Nelly
E30_Aza wrote:cliffy, DO SOME FUCKIN WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
stuartgallafant
cliffybabe
- Powered by Nelly
stuartgallafant wrote:you crazy kids!!!
