are there any guides on how to replace the waterpump & the fan couplings,im going to be replacing them and the haynes manual is no good.
cheers
waterpump-viscous fan (how to fit?)
brightyboy
kevin316i
Fan coupling is covered OK in the Haynes manual, waterpump instructions are also reasonable. What aspects of the Haynes are you concerned about? Viscous fan coupling is very straightforward.
brightyboy
gooner1
- Out humping Reindeer
Diy mate ,piece of piss.If you do a search for changing timing belt that should cover it,
