how easy is it to change the double fog light switch?
I think my one has had it. Do I need to remove the steering wheel and instrument cluster just to change it. I only ask this after looking at the website that shows you how to remove the dashboard.
CAn any one show some pics?
eldarvanyar
stevetigger
Remove panel above knee!
Put hand up behind fog light button, push from behind.......out it pops!
eko
- Old timer
Drop the panel above your knees(3 plastic screws along top),put your hand up behind the switch,push it out,unplug,refit!
beardymat
- Location: sheffield, city of steel, and rust apparently
remove the under dash trim by turning the plastic clips by 1/4 turn and you should be able to push the switch out from behind.easy peasy
beardymat
well three people cant all be wrong.lol.
eldarvanyar
Thanks guys, after having read the change a dahboard link I thought I had to remove the steering wheel and instrument cluster, DOH!!!!!!!
