As in the title, everything was working fine and then i went to start the car earlier and nothing!
Ive quickly checked the fuses and found a blown one (no 16 i think) which i replaced but still nothing.
Its a bit dark to see now but any suggestions i can try in the morning would be appreciated!
Tom
Heater/air con has completely stopped!
michealewk
belt broken maybe thats what happened to me
tomson
No, belt is fine im guessing this is electrical..........
tomson
bump, anyone please
Bally
had the same prob not sure but with mine , where the stereo had been taken out and replaced made it tight around the heater switch and the wiring connecors to the switces the heater air leecy roofwhich caused a short havea look behind switches look at connecters not at the switch connector i took mine to local air con guy who gave me number for leccy who sorted it out in 10 mins (easy when you know what you are doing ) good luck
tomson
cheers Bally, ive had a look where you mention but can nothing out of place.
Anyone else please?
Anyone else please?
