Box is from an E36 M3 with a lightened M20 flywheel & M20 starter.
On the M50 loom, there are three wires to the starter motor; two thin ones for the solenoid and a thick red that goes to the main terminal.
When I pulled the engine & loom, I don't recollect seeing any other wires to the starter.
I'm assuming that the thick red goes from the starter to the alternator and I can't see any of the wires in the original M50 loom being man enough to take the current draw for starter cranking so the question is, will I need a seperate wire from the battery down to the starter?
Help would be appreciated guys
