Hey just a quick question, should the throttle wire be a bit loose and sloppy when the cars a idle? or should it be tight via the ajustment it has ?
cheers
Sloppy throttle wire
drifty325i
cliffybabe
- Powered by Nelly
it should be tight but not to the extent of making it idle high though
massive
all the ones ive seen are quite slack within reason. Put a picture up if unsure, we like pic's
d6dph
i was told as long as the throttle opens fully when the pedal is flat to the floor, its fine?
drifty325i
Year i think the slackness is within reason, and im dam sure it gets full throttle lol. ill check
tomo cheers fellas
tomo cheers fellas
