replacing rear discs/pads
cheesebox
Post Thu Aug 17, 2006 2:23 pm
I wondered if anyone knew of any technical guides or threads on how to replace rear disks and pads (91' 318is) - it's a job I need to do this weekend...
Thanks in advance!
Fushion_Julz
Post Thu Aug 17, 2006 4:52 pm
The Haynes manual is on line here http://hosting.data.bg/bmw/BMW/E-Books/ ... 20-%20E34/
but the job is a pretty easy one, tbh....
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
kidsinister
Post Fri Aug 18, 2006 12:33 am
You'll need a 7mm (?) allen key for the job; either a caliper bolt key or an allen key socket, (for the pad retaining bolts), and some serious leverage to loosen the caliper housing bolts. Apart from that, it's a doddle. Just remember to leave the handbrake off (ahem).
Chris-W
Post Fri Aug 18, 2006 6:50 am
And a 5mm allen key / socket to remove the disc retaining screw.
cheesebox
Post Fri Aug 18, 2006 8:21 am
Nice one, thanks all for the tips/encouragement! I'd assumed for some reason it would be a pain in the ass...
